Stepper Question
I am trying to make a CNC mill (Small one) Using the basic stamp. I
am trying to use two stepper motors. I got a good program (i think).
But I need help with what tipe of all thread (a long bolt without a
head) I need. The steppers that I am using has a 1.8deg per step. And
I want the table to move .001" per step. Please help.
lets see...
360 degrees / 1.8 degrees per step = 200 steps per rotation.
This means you want one rotation to go 200 thousandths of an inch, or
1/5th of an inch. So, using a shaft with 5 threads per inch would
get what you want.
However, a 5 TPI (threads per inch) screw is way huge and probably
won't give you enough mechanical advantage. My little Sherline mill
uses a 20 TPI lead screw. I'd suggest you go with something standard
and readily available, like a 1/4" 20 TPI (course thread) lead screw,
or if you need it more beefy a 7/16" 20 TPI (fine thread). Since 20
is easily divisible by 5, you won't have to worry about any floating
point math with the stamp, and you'll get better accuracy.
Stew
>And
>basicstamps-unsubscribe@yahoogroups.com
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to
>http://docs.yahoo.com/info/terms/
Stewart Mayer, stewlist@k... on 11/15/2001
They are sometimes sold in the surplus outlets like Mouser.
Dennis
Sent: Thursday, November 15, 2001 5:01 PM
Subject: [noparse][[/noparse]basicstamps] Stepper Question
this kind of stuff.
As far as the thread pitch, your stepper motor apparently makes 200 steps
per rotation, which means you need a lead screw with 5 threads-per-inch.
360 degrees / 1.8 degrees = 200 steps per rotation
0.001 per step x 200 steps = 0.20" per rotation
1" / 0.20" = 5 TPI
Might want to check out the Heavy Iron articles in the last 4 or so Nuts &
Volts issues -- a guy is using an X-Y table to make a mill.
math!
I'm too lazy to go in the garage and check, but I think most smaller lathes
and mills typically move 0.050 per turn of the crank on the cross / compound
/ longitudinal feed. (Unless its a weird Chinese / Indian / Pakistani made
product, and then its something weird like 0.062" per turn.
> I'm kind of a novice stamper, but I've been machining for a while so
> lets see...
> get what you want.
> >And
the sun when it comes to the kind of parts your looking for. Including
lead screws from 1/4x20 to 1x10
Also leadscrew Supernuts
On Fri, 16 Nov 2001 01:01:17 -0000 iamturbo2000@y... writes:
> And
Sent: Friday, November 16, 2001 4:04 AM
Subject: Re: [noparse][[/noparse]basicstamps] Stepper Question
It is not weird at all, it is metric, used by all the world
except US.
Regards
ECO
or 0.063 (or 0.064) -- God bless dial indicators.
We do use metric here though -- most US-made cars are half and half. My
wife's Nissan (Mercury) van has SAE bleeders on the front brakes and metric
on the rear.
> except US.
