Low Voltage RCtime — Parallax Forums
Low Voltage RCtime
edited 2001-11-14 21:02 in General Discussion
I need to measure a voltage range of 0 to 45 mV using BS2's RCtime
command. What is the resolution on such low voltage? Should I
amplify the signal? How do I do that linearly?
Al Najjar
    >Al Najjar
    Hi Al,
    It can be done, but you need an op-amp circuit to convert the small
    voltage to a current. (VCCS: voltage controlled current sink) The
    resolution of the RCtime command is around 10 bits. Here is some
    information:
    http://www.emesys.com/BS2rct.htm#SmallV
    The resistor R1 could be 1kohm to convert 0.1-45 millivolts to 0.1-45
    microamps, and C1=0.01uf. That will give an RCtime count of about
    145 when the input is 45 millivolts and 65535 when the input is about
    0.1 millivolts. The RCtime value is inversely proportional to the
    input voltage, and the response does not go all the way to zero with
    the circuit as shown.
    Do you have a particular reason you want to use RCtime instead of an
    A/D converter?
    -- best regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
