polar to rectangular conversion
I need help converting an A/D output that corresponds to 0 to 360 degrees of
rotation to X and Y co-ordinates that I will use to move the cursor on a
computer screen around using the Mouse interface. I know how to implement the
Mouse protocol but am not real sure of the best way to transform the 0 to 360
degrees (0 to 1023 bits from a 10 bit A/D) into the corresponding X and Y
values. I would appreciate any help or suggestions from anyone in the group!
Thanks!
George (azeasi@a...)
Thanks!
If you mean you want to make a polar to rectangular coordinate conversion,
you don't have enough information. You have an angle, but you need a
distance from the vertex of that angle before you can make a P-R
conversion. How do you want the 0-359 degrees, or 0-1023 value, to be
mapped onto your screen?
Jim H
my X and Y values will be from -1 to +1. For instance, if I am at 0 degrees,
I want X = 0 and Y =1. at 360 degrees same values, at 90 degrees X = -1 and Y
=0, at 180 degrees X = 0 and Y = +1, and at 270 degrees X=+1 and Y=0. Hope
this clarifies what I am trying to accomplish. I thought I could use X=sin
(angle) and Y= cos (angle) since radius is 1. Since Stamp can't deal with
fractions I could scale everything by 10 and still get reasonable resolution
(I think). Am I on the right track? Do you have any ideas on a better way to
do this. I will probably want to use a PIC 16F876 or one of the other parts
with a built in A/D later on. For now I just want to get my algorithm nailed
down.
Thanks again for your quick response!
>I am assuming a unit circle, so the absolute distance is 1. Therefore all of
Yes and no. I think you might have some typographical errors in the signs
on some of the values you just gave. You can have it any way you want, but
the norm for me is to measure the angle from the horizontal, and work
counterclockwise, with X being the horizontal axis and Y the vertical. So
for me:
0 deg - X = 1, Y = 0
90 deg - X = 0, Y = 1
180 deg - X = -1, Y = 0
270 deg - X = 0, Y = -1
I think you are measuring from the vertical in which case and working
counterclockwise:
90 deg - X = -1, Y = 0
180 deg - X = 0, Y = -1 (you wrote +1)
270 deg - X = 1, Y = 0
>I thought I could use X=sin(angle) and Y= cos (angle)
>since radius is 1.
I agree.
>Since Stamp can't deal with fractions I could scale everything by 10 and
>still get reasonable resolution (I think). Am I on the right track?
You're definitely on the ( or at least a) right track. But I don't know if
you'll get reasonable resolution. How do you plan to display the
result? Does the display have enough resolution that the plotted point
should be in a different place with only a 1 degree change? If not, how
many degrees change is needed to make a difference in what the display can
show? The Stamp, because of the games you're playing with accuracy and
precision, may not produce a unique output for each unique input. If I
were you I'd write a little program on the Stamp to take values from 0 -
1023 and calculate the output you want and see if that output will produce
the values you need to get an acceptable plot. If it passes that test it
looks like you have a good plan!
>Do you have any ideas on a better way to do this. I will
>parts with a built in A/D later on. For now I just want to
>get my algorithm nailed down.
The algorithm sounds fine, but... on your Stamp you'll be playing the games
you mentioned to get accuracy and precision. On the PIC 16F876 you have 8K
of program memory. I bet you can find the code to implement a reasonably
accurate sine and cosine directly so you don't have to play games. The
display resolution may well be the deciding or limiting factor.
Good luck.
Jim H
not really a "pot" but electrically simulates a pot (i.e., voltage divider
output based on position of "wiper") so it is linear. Yes, I will need to add
an offset value to make my zero position correspond to zero degrees. My
desired zero position corresponds to the 6 o'clock position with 90 degrees
at 9 o'clock , 180 degrees at 12 o'clock and 270 degrees at 3 o'clock. My
actual zero position is more like 5 o'clock. The signs I described earlier
were based on the signs used by a standard Mouse (Up is +Y, Down is -Y, Right
is +X, and Left is -X) Thanks for the bit on screen resolution, it brings up
something I hadn't considered earlier. I know the Stamp is not fast enough to
use as a Mouse interface but I figured I could use the technique I developed
and optimized using the Stamp and build the final circuit using the PIC or
perhaps even an SX. Thanks again to all who responded!
I think you should start with the definition of your display.
Assume a 2N+1 by 2N+1 pixel square with the origin in the middle.
So your X lies between -N and +N and so does your Y.
Assuming the 1023 output reflects a full circle you must translate that
to the argument for the sin and cos functions which take 0-255 radial units
for a full circle.
So, divide your AD value 0..1023 by 4, giving you 0..255.
The sin and cos function return -127 to +127, probably using 2-complement
i.e 255 equals -1 and 128 equals -127.
The X and Y function become (mathematical)
X=N*cos(AD/4)/127
Y=N*sin(AD/4)/127
You must split this into positive and negative parts
If cos(AD/4)<128 then X=N*cos(AD/4)/127 else X=-N*(255-cos(AD/4))/127
If sin(AD/4)<128 then Y=N*sin(AD/4)/127 else Y=-N*(255-sin(AD/4))/127
Your display origin is located at XD,YD of your screen
So your screen coordinates become (assuming screen origin left below)
SX=X+XD
SY=Y+YD
Note: X,Y,XD,YD should be byte variables.
There are still some details to fill in, such as: does your AD value 0
correspond to
angle 0, if not you must add a offset angle, rounding errors etc. but it may
give you a start.
The resolution you get is mainly defined by N with N=127 giving max.
resolution.
Regards peter
Oorspronkelijk bericht
Van: Jim Higgins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e1T18eVY9TsP97BC3CF9MW_oMiDKNSs4v__zU9N2dTjmnsV51y12_2VrVtpZfBB6QEs02b9njBxY]HigginsJ@s...[/url
Verzonden: zondag 11 november 2001 14:07
Aan: basicstamps@yahoogroups.com
Onderwerp: Re: [noparse][[/noparse]basicstamps] polar to rectangular conversion
of
degrees,
Y
for me:
counterclockwise:
>since radius is 1.
I agree.
Good luck.
Jim H
graphics trick is to use reflective symmetry about both X and Y axes,
whenever it is appropriate. For example, to draw or track a circle, compute
only points from 0 to 45 degrees, and then plot their reflected mirror
images about both axes into all 4 quadrants. Saves both computing and
memory for any stored tables.
Dennis
Sent: Sunday, November 11, 2001 2:06 PM
Subject: Re: [noparse][[/noparse]basicstamps] polar to rectangular conversion
of
degrees,
and Y
Hope
but
> for me:
> counterclockwise:
> >since radius is 1.
> I agree.
if
games
8K
> Good luck.
> Jim H
