But is SAYS nibble addressable...
In addition to other replies, consider the fun you can have with:
'{$STAMP BS2}
nibble VAR B0.LOWNIB
index VAR BYTE
nibble( 1 ) = 15
nibble( index ) = 2
And so on. As Doc Allen pointed out many moons ago, all variables
are implicit array elements. So when you declare a nibble (or
bit/byte/word) variable, you are also defining the 0th element of an
array of nibbles (or bits/bytes/words). Automatic memory address
assignments in the BS2 and beyond can complicate the picture--think
everything through to avoid premature hair loss.
Steve
On 9 Nov 01 at 10:59, Astro Fizzix wrote:
> Look at the NOTE at the bottom of Table 4.2 on page 47 of the basic
> stamp book. It says that ALL registers are word, byte, NIBBLE AND
> BIT addressable. So what are their names?...
'{$STAMP BS2}
index VAR BYTE
nibble( 1 ) = 15
nibble( index ) = 2
Steve
It says that ALL registers are word, byte, NIBBLE AND BIT addressable. So what
are their names? I've tried all I can think of (NIB4, N4, NIBBLE4) and I can't
figure it out. The book doesn't say much on fixed variables, in fact, it acts
like your an idiot if you don't use allocated variables. Now, I'm sure that
those good people at Parallax spent a lot of time creating the hardware for
allocated variables, but they act like that's the only way to go...but that's
just my opinion, I could be wrong...
So what's the deal? What is the syntax? Is this just a despicable lie?????
>Look at the NOTE at the bottom of Table 4.2 on page 47 of the basic stamp
>book. It says that ALL registers are word, byte, NIBBLE AND BIT
>addressable. So what are their names? I've tried all I can think of (NIB4,
>N4, NIBBLE4) and I can't figure it out. The book doesn't say much on fixed
>variables, in fact, it acts like your an idiot if you don't use allocated
>variables. Now, I'm sure that those good people at Parallax spent a lot of
>time creating the hardware for allocated variables, but they act like
>that's the only way to go...but that's just my opinion, I could be wrong...
To answer your question directly, the syntax is HIGNIB and LOWNIB.
Check Table 4.3 on Page numbered 56 - just a few pages from where
you were.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Reserved names for variables are b0-b25 for bytes and w0-w12 for words.
Nibbles are addressed using a modifier like b10.highnib or b10.lownib or
b10.nib0
Bits are addressed using a modifier like b7.bit0 or w3.bit6 etc.
IT IS all explained in the manual. Read carefully.
Regards peter
Oorspronkelijk bericht
Van: Astro Fizzix [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_liebVKn1yrEtdAHnUcMVOcjANrlh4hBfww32yuEEQiUGvfS5mOTzsG3cp8eS5Ail_OjYHQqOecG0qY4vqaR4A]astro_fizzix@y...[/url
Verzonden: vrijdag 9 november 2001 8:59
Aan: Post BS Message
Onderwerp: [noparse][[/noparse]basicstamps] But is SAYS nibble addressable...
time creating the hardware for allocated variables, but they act like that's
