Trouble with MAX232 — Parallax Forums
Trouble with MAX232
edited 2001-11-07 19:11 in General Discussion
Hi all,
I am trying to set up a MAX232 to debug my serial communications between my BSII
and a PIC16F84, however I am having trouble with a hardware problem...
I have set my MAX232 up exactly as the datasheet says for a typical
configuration (using 4 1uf caps) and have connected the stamp output pin
directly to one of the MAX232 TTL inputs.
I have written a little bit of pbasic that simply prints out the ASCII character
'A' over and over... however when I start up my terminal program I get the
following:
    edited 2001-11-07 11:40
    MAX232 inverts the output. It takes a standard TTL RS-232 signal which is
    held low and pulled high by data, and converts it to a PC-compatible RS-232
    signal which is held high and pulled low by data. You need to get the data
    coming out of the Stamp the right way and it should work.
    BSII and a PIC16F84, however I am having trouble with a hardware problem...
    character 'A' over and over... however when I start up my terminal program I
    get the following:
    edited 2001-11-07 18:40
    Hi Rodent and Peter,
    thanks for your replys!
    Peter wrote:
    <snip>
    You probably have the incorrect constant for the baudrate.
    You must use the value for connect through line driver which
    Is different than the value for port 16
    Check the manual.
    <snip>
    Doh! I HAD read the manual, however on going back just now to referrence the
    page I noticed what you mean by different values for non-inverted line
    driver.... changed the value and BAM! it works :-)
    Thanks so much for your help,
    kind regards,
    James Fitzsimons
    edited 2001-11-07 19:08
    Check the manual.
    Regards peter
    Oorspronkelijk bericht
    Van: James Fitzsimons [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eSbxm2gWKPVgEYJOxO3213v_8DaVtTKOLTz7uzxcRHTIeawqtCSX7Ms9JHqAaPLqrrXKPkg3v0tefogRdaI]jamesfit@p...[/url
    Verzonden: woensdag 7 november 2001 1:14
    Aan: basicstamps@yahoogroups.com
    Onderwerp: [noparse][[/noparse]basicstamps] Trouble with MAX232
    Hi all,
    get the following:
    I use the following constants in my programs using the MAX232 (BS2SX)
    'baudrate definitions for bs2sx (through line driver)
    E71_1200 con 10255
    E71_2400 con 9213
    E71_4800 con 8692
    E71_9600 con 8432
    E71_19200 con 8302
    E71_38400 con 8237
    N81_1200 con 2063
    N81_2400 con 1021
    N81_4800 con 500
    N81_9600 con 240
    N81_19200 con 110
    N81_38400 con 45
    Regards peter
    Van: James Fitzsimons [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FutfLeDX5TJz2EzM-EmRGWcnG08XWAPRIvtwCSo_s5cPNFjwrg1sJQG3ajRMQL9YS3LsfD8nnljM9vEpNvCmD0IA]jamesfit@p...[/url
    Hi all,
    get the following:
