servo controller with presets AND joystick control?
Hello All:
Does anyone know of a stand alone (no PC) servo controller or stamp program
that allows servo control to two servos via a joystick, as well as a memory
function, allowing the joystick commands to be memorized into 3 or 4 memory
presets?
If not, what would it cost to have a program for a stamp written that would
supply these operations? (I have all intentions of learning basic or oopic,
but need this application ASAP - sorry If I'm offending anyone...)
presets?
the movement if memory is required. Please see:
home1.gte.net/tdickens/68hc11/servo/servo.html
there is a circuit here that will accomplish these goals.
Kind regards,
Leroy Hall
"Witherspoon, Michael J" wrote:
> Ed,
> Check the Nuts & Volts web site http://www.nutsvolts.com back issues. They
> did this very project a year or so ago. I don't remember if it was a Stamp
> or a PIC though.
> Mike Witherspoon
> From: Ed Elser [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1wpPXU6-ee6rVFkcnDHj9ZlaoBKIZ7ygZr9PyqiUbAD-MLX0r-JAcEoGGmltPVngujubmvjIVfC4rNg]eelser@s...[/url
> Sent: Tuesday, November 06, 2001 2:53 PM
> Subject: [noparse][[/noparse]basicstamps] servo controller with presets AND joystick
> control?
> Hello All:
> presets?
> Body of the message will be ignored.
> This can be done with a 556 timer chip. Use precision 10 turn pots for
http://home1.gte.net/tdickens/68hc11/servo/servo.html
> Kind regards,
> Leroy Hall
> > Ed,
> > or a PIC though.
> > Mike Witherspoon
> > From: Ed Elser [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fPZkLCqAJVI3HZqd7K-PwvR7-0c2uPQhXfVPPWf1xgrAY523VO_m_grCTjbJisy3T9kWCWg5IQ]eelser@s...[/url
> > control?
> > Hello All:
> > presets?
a controller with 555 ic's very easily. You could use trimpots to
'preset' your 'memorized' settings and use switches to and pots for
the variable settings. Hold the button as you move the joystickfor
variable settings and let go of the button for the 'memorized'
settings.
Hope this helps. I'll dig around for the circuit to do this with. . .
Doug
On 6 Nov 2001, at 16:52, Ed Elser wrote:
> Hello All:
> program
> memory function, allowing the joystick commands to be memorized into 3
> or 4 memory presets?
> would supply these operations? (I have all intentions of learning
> basic or oopic, but need this application ASAP - sorry If I'm
> and Body of the message will be ignored.
Doug
> Hello All:
> program
Other than an RC radio I dont know of anything. You need to be a little
more specific about what you want.
On Tue, 6 Nov 2001 16:52:59 -0500 "Ed Elser" <eelser@s...> writes:
> Hello All:
> program
> memory
> memory
> presets?
> that would
> oopic,
