Could BSII-p stand the bit flow of this b/w camera?
These are the specifications of the camera i found at
http://www.electronic-kits-and-projects.com/cmos_cameras.htm
M3188A - 1/3" Monochrome Camera with Digital Output
General Description
The M3188A is a 1/3" monochrome camera module with digital output. It
uses OmniVision's CMOS image sensor OV7120. Combining CMOS technology
together with an easy to use digital interface makes M3188A a low
cost solution for higher quality video image application.
The digital video port supplies a continuous 8 bit-wide image data
stream. All camera functions, such as exposure, gamma, gain,
windowing, are programmable through I2C interface.
Camera is supplied as standard with an f7.4mm F2.1 lens.
Click here for PDF Data Sheet on this camera. You can also download
the evaluation board software for this camera from our Software
Downloads page.
View of camera board and sensor (lens & mounting removed)
Features
307,200 pixels, VGA / CIF format
Small size : 40 x 28 mm
Read out - progressive / interlace
Data format - 8 bit video data
I2C interface
Electronic exposure / Gain / Control
Image enhancement - brightness, contrast, gamma, sharpness, window,
etc
Internal / external synchronization scheme
Frame exposure / line exposure option
Single 5V operation
Low power consumption (<300mW)
Monochrome video output (60Hz version only)
Specifications
Imager: OV7120 colour CMOS sensor
Array Size: 664 x 492 pixels
Pixel size: 7.6 x 7.6 mm
Scanning: Progressive / interlace
Effective image area: 4.86mm x 3.64mm
Electronic: Exposure 500:1
Gamma Correction: 128 Curve settings
S/N Ratio: >48dB
Min Illumination: <0.5 lux @F1.4
Operation Voltage: 5±0.5 VDC
Operation Current: 200mW Active, 10mW Standby
Lens: f=7.4mm F2.1
Applications
Still Image
Machine Vision
Process control
Finger print recognition
Bar code scanner
General Description
Downloads page.
Features
I2C interface
etc
Single 5V operation
Specifications
S/N Ratio: >48dB
Lens: f=7.4mm F2.1
Applications
Still Image
Machine Vision
Process control
Bar code scanner
General Description
output. It
technology
Downloads page.
Features
I2C interface
etc
Single 5V operation
Specifications
S/N Ratio: >48dB
Lens: f=7.4mm F2.1
Applications
Still Image
Machine Vision
Process control
Bar code scanner
