Experiment 26 (Stamp Works)
I am working on stamp works experiment #26. I think I have
everything hooked up correctly and typed in the code. But when I run
the stepper vibrates but doesn't turn. It's like the coils are being
activated, but not in the correct sequence. Any help you can give is
greatly appreciated.
Bill
potcw con 0
potccw con 1
coils var outb
speed var word
x var byte
saddr var byte
rcrt var word
rclf var word
diff var word
step1 data %1100
step2 data %0110
step3 data %0011
step4 data %1001
initialize:
dirb = %1111
speed = 5
main:
for x = 1 to 100
gosub stepfwd
next
pause 200
for x = 1 to 100
gosub steprev
next
pause 200
stepdemo:
high potcw
high potccw
pause 1
rctime potcw,1,rcrt
rctime potccw,1,rclf
rcrt = rcrt max 600
rclf = rclf max 600
diff = abs(rcrt - rclf)
if (diff<25) then stepdemo
if (rclf>rcrt) then stepccw
stepcw:
speed = 60 - (rcrt / 10)
gosub stepfwd
goto stepdemo
stepccw:
speed = 60 - (rclf / 10)
gosub steprev
goto stepdemo
stepfwd:
saddr = saddr + 1 // 4
read (step1 + saddr),coils
pause speed
return
steprev:
saddr = saddr + 3 // 4
pause speed
return
Bill
potcw con 0
potccw con 1
coils var outb
speed var word
x var byte
saddr var byte
rcrt var word
rclf var word
diff var word
step1 data %1100
step2 data %0110
step3 data %0011
step4 data %1001
initialize:
dirb = %1111
speed = 5
main:
for x = 1 to 100
gosub stepfwd
next
pause 200
for x = 1 to 100
gosub steprev
next
pause 200
stepdemo:
high potcw
high potccw
pause 1
rctime potcw,1,rcrt
rcrt = rcrt max 600
rclf = rclf max 600
stepcw:
gosub stepfwd
goto stepdemo
stepccw:
gosub steprev
goto stepdemo
stepfwd:
pause speed
return
steprev:
pause speed
return
the Parallax site -- I promise that it does work.
-- Jon Williams
-- Parallax
-- Author of StampWorks
In a message dated 11/4/01 4:16:23 PM Central Standard Time, DaMoos@a...
writes:
