How to stop HIGH pin from toggling — Parallax Forums
edited 2001-11-02 00:21 in General Discussion
I read somewhere how you could stop the repeated cycling of a pin,
which when held in a HIGH state is set to LOW for a very short
duration, as the BS2 does its housekeeping. When I set one of the
pins HIGH, it must stay in that state, without a single glitch,
until told to go low. This pin is actually supplying the bias
voltage to the input transistor in an oscillator stage, so a
momentary interruption of that voltage is going to play havoc with
the oscillators.
Is there a way to wire up a filter circuit, or maybe just a cap or
two, that would effectively isolate a downstream component from the
intermittent "toggles"?
thanks, and I hope you know what I am talking about !!8-)
Jim D. Martin
    edited 2001-11-02 00:01
    If what you're experiencing is the Stamp Watchdog Timer (used during certain
    low-power modes), a possible solution would be to pull the pin high through
    a pull-up resistor (e.g. 10K). Then the Stamp can pull that pin low as
    required to turn off the oscillator.
    -- Jon Williams
    -- Parallax
    In a message dated 11/1/01 5:53:06 PM Central Standard Time,
    jimdmartin@a... writes:
    > the oscillators.
    > thanks,
    >the oscillators.
    >Jim D. Martin
    Hi Jim,
    Exactly.
    However, the pins do not go LOW. They become inputs. That is an
    important distinction. The usual solution is one of the following:
    1) provide a pullup resistor at the input to your oscillator circuit
    sufficient to maintain it in operation during the glitch. The pullup
    will hold the circuit at a high level.
    2) put a capacitor in parallel sufficient to hold the voltage for the
    ~18 milliseconds duration of the glitch. The capacitor will hold
    whatever level the BASIC Stamp gave it, provided your circuit does
    not draw too much current.
    This glitch is a characteristic of the microprocessor underlying the
    Stamps. It occurs when the Stamp is reset, and during the execution
    of the SLEEP, NAP or END instructions. All i/o pins becomes inputs
    for a brief instant when the Stamp wakes up. During a long SLEEP
    interval for example, the stamp wakes up once every ~2 seconds to
    check on its status. For ~18 milliseconds each time, all pins become
    inputs, and then they revert back to their programmed state as HIGH,
    LOW or INPUT.
    -- best regards
    Thomas Tracy Allen PhD
    http://www.emesystems.com
    mailto:tracy@e...
