Infrared Troubles...
I need to send a 40khz freq to an infrared led to be detected by a metal can
detector (you know, from Radio Shack). I'm using the BS2, and it does seem to
output the signal, but it does not work. My real problem is that I can't get the
correct freq out...my math says that I need to use a 12.5 period on PULSOUT, but
you can't use decimal values. Freqout doesn't work, I've already tried 32khz,
but to no avail. ANY help is appreciated...
measurement. [noparse]:D[/noparse]
Mensaje original
De: Astro Fizzix [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9YAXyW96Ni_i1p7vOnsO4-KXBRUDPmjbAAf_ch28CqJWbG6VPGBngO6FNMNLHUOQtmSJq3aEKbzvPBbIBUo]astro_fizzix@y...[/url
Enviado el: Mi
the LED, can be easily controlled by the stamp. Frees up the stamp to
do other things.
metal can detector (you know, from Radio Shack). I'm using the BS2,
and it does seem to output the signal, but it does not work. My real
problem is that I can't get the correct freq out...my math says that
I need to use a 12.5 period on PULSOUT, but you can't use decimal
values. Freqout doesn't work, I've already tried 32khz, but to no
measurments, I have always been curious about how that works, if it's not too
much trouble...
ranging from 0-25cms max, just connect an IRLed and receiver and point
them in the same direction so the light emmited by the led can return to
the receiver once it's reflected back from a surface (the brighter the
surface the more distance can measure), then use freqout on the emmiter
to generate a 40khz signal for 1ms then check the receiver status and
there you go, a 1 must appear if an object is in the range, if you try
several frequencies you can obtain several distances, using lookup helps
a lot!!
Here's the program that does it:
counter var nib
l_val var byte
r_val var byte
ir_freq var word
main:
l_val=0
r_val=0
for counter=0 to 4
lookup counter,[noparse][[/noparse]37500,38250,39500,40500,41500],ir_freq
freqout 15,1,ir_freq
l_values.lowbit(counter)=~in14
debug home,cr,cr
debug " ",bin8 l_values
debug " ",dec5 ncd(l_values)
goto main
NOTE:
Don't separe the "freqout" line from the "l_values" one, if you do so
you won't be able to recover the bit before it disappears, also put a
.1uF capacitor between Gnd and Vdd on the receiver pins. Have Fun!!
If you need more help just contact me again!!
(sorry about my English [noparse]:)[/noparse] I'm from Venezuela and I'm 17 years old)
Mensaje original
De: Astro Fizzix [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hZChI0bRN9aFk33Epa7PhW-LWx7ORMY0T_wkIb6P_EfRPTXEdPKCoUXw4TRWVH1HKJlsNj2eDqSnNIKgew]astro_fizzix@y...[/url
Enviado el: Viernes, 02 de Noviembre de 2001 11:40 a.m.
Para: Post BS Message
Asunto: [noparse][[/noparse]basicstamps] RE: Infrared Troubles...
Carlos, I was wondering if you'd explain what setup you have for
distance measurments, I have always been curious about how that works,
if it's not too much trouble...
Your use of Yahoo! Groups is subject to
where my problem is...however, I assume from your code that different freq's
send out different light strengths. Kinda like the brightness of an LED. Is that
correct? I can hookup a little 555 setup and generate the 40khz or whatever I
want, so what you have shown me is very helpful, thank you!
By the way, sounds like you and me are on the same level, I'm 18.
that the range and reliability of the sensor was not so good. I switched to
the Sharp modules and have had no problems.
> Wow, that's great! But, the BS2 can only generate a MAX of 32.7khz, which
is where my problem is...however, I assume from your code that different
freq's send out different light strengths. Kinda like the brightness of an
LED. Is that correct? I can hookup a little 555 setup and generate the 40khz
or whatever I want, so what you have shown me is very helpful, thank you!
