Newbie Question Re. ASCII
Hi! I am new to this list and had a quick question regarding ASCII.
I am working on a project (using the Basic Stamp II) that does a
simple math problem, then writes the answer to the EEPROM using the
WRITE command. The EEPROM contents later are sent to a 4-bit
parallel LCD display. My question is how to convert the decimal
number from the math problem into ASCII for the LCD display. I know
this sounds like a simple problem, but I'm not very experienced with
the Basic Stamp.
Jacob
the Basic Stamp.
Jacob
ASCII.
know
with
> the Basic Stamp.
> Thanks,
> Jacob
Hi Jacob,
One simple, but not the most efficient, way would be to load the
decimal number, bit by bit, into an array, and the parse the array,
one bit at a time with the ASC qualifier, i.e. x=ASC(decimalnumber,1)
and so on. (But come to think of it, that would be one way to do it
in VB, so not sure if that will help you.)
Jim
>the Basic Stamp.
>Thanks,
>Jacob
Hi Jacob,
Something like this
read location, mybyte
for j=2 to 0
char=mybyte dig j + 48 ' get jth digit, add 48 for ascii
gosub char2lcd ' put it on the lcd, not shown
next
That prints the leading zeros, for example, 005, 013, 154, always
three digits. The following substitutes spaces for leading zeros, so
the above would be 5, 13 or 154, right justified:
nonzeroflag var bit
mybyte var byte
location data 154
j var nib
digflag=0 ' flag turns to 1 at first significant digit.
for j=2 to 0
char=mybyte dig j ' char is jth decimal digit
digflag = char max 1 | digflag
char=(digflag-1)*16+ char+48 ' convert to ascii
' and convert leading zeros to spaces
next
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
front of your variable
ie(serout pin,baud,[noparse][[/noparse]254,120,dec2 variable]
If your using an lcd with a backpak installed you will need to initialize
the display,which is 254, and a start position followed by your variable.
On Thu, 01 Nov 2001 02:32:25 -0000 sejpower@j... writes:
> the Basic Stamp.
> Thanks,
> Jacob
> from the same email address that you subscribed. Text in the
