Help! Need to know how to do Manchester Encoding/Decoding
Archiver
I need some help with the Basic Stamp 2. I am building two vehicles
that will have the ability to transfer information to eachother as
they move around in areas. Our design project is using the Basic
Stamp 2 micro controller. My question is, i am required to do
Manchester Encoding/Decoding to send out and recieve the data via our
transceivers, and was wondering if anyone knows how to do this? If
so, please email me! As well, I was wondering if i can make a
circuit that can be connected to the serial out/in of the basic stamp
that will automatically convert it to manchester coding, instead of
having to code it for the micro controller?
Thanks!
Debu
Thanks!
Debu
There are Manchester Encoding Decoding chips you can use.
Checkout:
http://www.intersil.com/data/FN/fn2/fn2959/FN2959.pdf
http://www.intersil.com/data/FN/fn2/fn2952/FN2952.pdf
You would place such a chip between stamp #1 and your transmitter and
between your receiver and stamp #2.
It should make the Manchester coding transparent to your program. However,
if the Manchester coding is part
of your assignment this would be cheating wouldn't it [noparse]:)[/noparse]
regards peter
Oorspronkelijk bericht
Van: debu_sen_22@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1taL8U7_lZeQh0L-w9Vh0oWWw1EQRl4Ige93xt13y1cxwl94MZCvvXPEcXrm5ZG57iq1BpD22aWf9en95owAVw]debu_sen_22@y...[/url
Verzonden: donderdag 1 november 2001 1:03
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Help! Need to know how to do Manchester
Encoding/Decoding
Thanks!
Debu
design project. We are trying to find a way to code it. Anyone have
any other ideas?
thanks
Debu
--- In basicstamps@y..., "peter verkaik" <peterverkaik@b...> wrote:
> Hi,
> Checkout:
and
However,
> regards peter
> Van: debu_sen_22@y... [noparse][[/noparse]mailto:debu_sen_22@y...]
> Aan: basicstamps@y...
> Encoding/Decoding
> Hi,
our
stamp
> Thanks!
> Debu
> basicstamps-unsubscribe@y...
Subject and
Take a look at the following link
http://www.mycal.net/projects/digital/encode.html
It provides program samples in C and a simple cheap circuit to filter out
data at the receiver end.
Also look at
http://www.erg.abdn.ac.uk/users/gorry/course/phy-pages/man.html
This shows the encoding: for a 0 send out 01 and for a 1 send out 10
i.e add 1 or 2 after shifting the result 2 bits to the left
You could encode in the following way:
charin var byte 'holds ASCII or binary character to send
wordout var word 'holds manchestercode for charin
bit var nib 'bitcounter
wordout=0
for bit=0 to 7
wordout=(wordout<<2)+charin.bit7+1 'add 1 or 2 after shifting
charin=charin<<1 'move next bit to bit7 position
next
serout pin,baud,[noparse][[/noparse]wordout\16]
hope this helps
regards peter
Van: debu_sen_22@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SUr0H-jPj4snqtmXKUJ3r3CLaqyIbn6ezefEj2r8xnzV9QzjN8cRqgfjmSVdDfAI3s7P_hWXQpp_KpFD]debu_sen_22@y...[/url
Verzonden: donderdag 1 november 2001 19:08
Onderwerp: [noparse][[/noparse]basicstamps] Re: Help! Need to know how to do Manchester
Encoding/Decoding
Yea, we can't use the chips because we would be over budget with our
any other ideas?
thanks
Debu
> Hi,
> Checkout:
and
However,
> regards peter
> Encoding/Decoding
> Hi,
our
stamp
> Thanks!
> Debu
Subject and
Interesting links, Peter.
BTW the Stamp will choke on the instruction,
serout does only bytes!
The "wordout\16" is okay for the shiftout command.
From what I understand of Manchester, it will be hard to implement on
the Stamp. The transmitting end needs to send an extended sychronous
bit stream, and the receiving end needs a phase lock loop to recover
the clock. The external chips Peter suggested would do that.
Debu, you might take a look at the documentation that comes with the
Parallax RF Digital tranceivers. They include some program examples
written by Jeff Martin that implement data packets and check sums.
The data packet and checksum scheme greatly improves the reliability
of the RF link. Maybe you can convince your instructor that
reliability is the goal of the assignment?! Even if you do implement
Manchester, you still might want to packetize your data.
It has never been clear to me if the RF Digital modules from Parallax
are strictly AM keyed, or if they implement a transparent Manchester
scheme. They do have a microprocessor on the RF transceiver board,
something the cheap RF modules do not have.
Simple AM keyed tranmitters are much more sensitive to noise when
they are OFF (not transmitting) than when they are ON
(transmitting). Therefore, a good transmission scheme will minimize
the off time. One reason Manchester encoding is good for RF is that
the transmitter is never off for more than two bit periods. When the
level at the input to the Manchester encoder is steady, either high
or low, the output of the Manchester is a steady stream of
on-off-on-off.
Jeff Martin had also written example programs for the
now-discontinued DVP modules, the aim of which was to implement a
transmission scheme on the BS2 that would hold the keyed AM
transmitter ON for most of the time, and minimize the off periods. I
don't see that document on line, but you might send an email to
Parallax to see if it might still be available.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Hi,
>Also look at
>wordout=0
>for bit=0 to 7
>next
>hope this helps
>regards peter
>Van: debu_sen_22@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DCtRVD6spxfIf647rg0VuMUiCAvFhOTTW6iopZY9Ppmm3lpQhG0LkfNMQzN6_2o5SsUyMyBxR0spK0U]debu_sen_22@y...[/url
>Encoding/Decoding
>any other ideas?
>thanks
>Debu
>> Hi,
>> Checkout:
>and
>However,
>> regards peter
>> Encoding/Decoding
>> Hi,
>our
>stamp
>> Thanks!
> > Debu
story.
Those chips only cost retail about $9.00 each and the work both
receive and transmitt.
Might be worth looking into.
73 spence
