A cable for SMS phones etc
I have been reading this list and surfing the web for some info on
controlling a GSM phone from a stamp. So far I have managed to find various
links etc on various cables. I have even went and bought a commercial cable
that seems to work with my phone with various bits of software but I am
unable to get it to work with a terminal package. the reason for the
terminal package is if I can do this with AT commands I should be able to
get it to do it using a serial out on a stamp with basically the same
commands. I realise there is another format of talking to the phone but my
research (and I would love to be corrected on this) has shown that you can
apparently use simple AT commands. I am not however trying to use the phone
as a modem. Simply send and recieve SMS messages
For the record I am using a Nokia 5110 as my test phone
Hence:
I have found a couple of sites with home made data cables etc and have
intentions of building one using a MAx3232 chip. I was wondering if some of
you would like to provide a link with a build it yourself data-cable type
web page that you have used to build a succesful design....
And I am confused as to the format of communications to the phone. Is it 7
or 8 bit at 9600 or what?
I would love to hear from anyone (on or off the list) about any of the above
of if you can offer any further links or info.
Warmest regards, Peter
Hence:
So far, I haven't been successful in sending SMS directly from
the stamp but I can point you to different links that helped me
move my research forward.
You should look at: http://www.daniel-hertrich.de/s25_hplx/
the schematics should probably work also for the stamp. So far,
I've used a commercial cable and I also tried connecting directly
to the mbus of the phone(only got garbage though).
I will add random bookmarks:
http://www.emesystems.com/BS2rs232.htm
http://multivac.fatburen.org/gnokii/6110-mailarchive/msg00019.ht
ml
http://multivac.fatburen.org/gnokii/6110-mailarchive/msg00117.ht
ml
http://multivac.fatburen.org/gnokii/6110-mailarchive/msg00045.ht
ml
http://gatling.ikk.sztaki.hu/~kissg/gsm/at+c.html
http://www.atrox.at/datacable/dlr3/
commercial link but a proof that it's possible:
http://www.dps-promatic.com/gsm.html
also: http://www.westplex.co.za/RTCU.html
http://www.ee.washington.edu/circuit_archive/circuits/
Of course, I hope it's only a matter of time before I figure it out,
and I will post further discoveries.
Btw, I got hyperterminal talking to a motorola timeport using a
cable sold by softgsm. Of course it only works through softgsm's
virtual modem, and when I tried to reproduce the same data
(recorded with portmon) inside the stamp, it didn't work. Some
phones like the nokia 3210 uses straightforward serial datas
and doesn't need a virtual modem installed on the pC in order to
send SMS to the phone. So far I found a cheap solution for my
project by using DTMF, but the type of data is very limited. Anyone
interested in using that can get the DTMF kit from parallax and a
pair of headsets for their phone(necessary , if not the phone
won't pick up automatically). With this, it makes a very fiable
remote control for the stamp.
Sorry if I went off the subject a bit... and if my links are not so well
organised. just hope it was useful for someone...
And I will be very greatful if anyonelse could also share their
links..
thomas charveriat.
