Proximity sensor
Archiver
I have a project to build a 10" diameter pad made of translucent
plexiglas that will light up when a hand or a "body" gets close to
it. The pad is layed horizontally on a table.
The lighting up is easy, I am thinking about three or four white
LEDs to do the job. As to sensing proximity I would like to know if
the IR sensor used in typical public bathrooms will work. This is
typical in urinals or lavatories. I think there is an IR emitter
and once enough signal is reflected back, a receiver send a signal
to the control system.
I know that I can use sonar like the polaroid 6500 or Sharp
equivalent, but I interested in a cheap but effective method as well
as simply understanding how to make an industrially strong method
using IR.
Any insight will be most appreciated.
thanks
Al
using IR.
thanks
Al
Qprox (www.qprox.com) makes a wide variety of capacitative sensors to
do exactly what you are proposing. They sell inexpensive single chip
solutions that are easily interfaced with the BasicStamp.
Peter
(not affiliated in any way with QProx, just very pleased with their
products).
Date: Tuesday, October 30, 2001 11:35 pm
Subject: [noparse][[/noparse]basicstamps] Proximity sensor
> if
> well
> using IR.
> thanks
> Al
> from the same email address that you subscribed. Text in the
http://www.glolab.com These are similar to sensors used in motion detectors
for lighting and alarm systems and are fairly inexpensive.
With an op amp and some output filtering repeatable results are easily had.
They even ship with a booklet containing a typical circuit that is a good
starting point.
Chris
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bi3yKXzWghKSZAWmdo1GklUnEXPXV3jT79bywQMZewMXyPf_hCGb0EMmtaX6SYMwFjLnCvDBu-ECGg]brownstamp@y...[/url
> Sent: Tuesday, October 30, 2001 11:36 PM
> using IR.
> thanks
> Al
for your project. You can even look at the stamp code there:
http://www.acroname.com/robotics/info/examples/GP2D02-4/GP
2D02-4.html
btw, you might want to try different type of sensors, I try to come
up with a small list of sensors, you can look at it there:
http://www.music.columbia.edu/~thomas/sensors.html
thomas charveriat
interference from external light. I bought all of mine from Acroname -- he
furnishes very good documentation on all his sensor modules.
> the sharp GP205 or th sharp GP202(more fun) will work perfectly
> 2D02-4.html
>The Sharp sensors are great. Decent range and very little if any
Just aware that the GP2D05 it is presently being discontinued by Sharp.
> > 2D02-4.html
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
by chance, read this thread and got quite interested. I've had a look
at the Qprox site and they have some ready-made stuff to 'play' with
(E6S2 board) but what I'd really like is to connect it to a basic
Stamp...
here's the rub, I'm pretty much a beginner at all this but when you
said
"VERY easy to connect to the stamp (If I say easy that must mean
EEEAAASY!)"
then I get a little worried, easy for you... but what about me?? So,
I've taken the easy way out...
Could you provide some really basic (no pun intended) instructions
and diagrams of what I need to get one of these chips (preferably the
QT60320) talking to a Basic Stamp.. and perhaps if you are feeling
really generous some example code for the communications between the
two...
Essentially All I'm aiming for is a control interface for my X10
lighting (that bit I *can* do for myself [noparse]:)[/noparse] ) that is hidden behind
various objects. e.g. Picture frame, bathroom tiles etc...
As I've said that comes later, my fundamental problem is just getting
some simple info on getting started... perhaps it's a good one for
the "BASIC Stamp Application Kit Documentation (includes source
code)" treatment...
Any help greatfully appreciated, I feel unworthy...
Andy
--- In basicstamps@y..., "ulibasic" <ulibasic@r...> wrote:
> Hi there,
> let me throw myself in for qprox here. After hesitating for some
weeks I
> finally followed the groups advice and got me one. They are simply
> fantastic!!!!
> They are very cheap, VERY easy to connect to the stamp (If I say
easy that
> must mean EEEAAASY!)and they do the job without light or distortion
> anything. Great job to create an integrated device like that!
> No, I am not on the qprox-paylist, ;-) I am just very happy about
that lil
> thing...
> Have a nice day, Uli
Urspr
Andy
--- In basicstamps@y..., "Andy Powell" <andy@h...> wrote:
> Sorry but this is a bit of a delayed reaction from me [noparse];)[/noparse]... I,
just
look
with
> Stamp...
you
> EEEAAASY!)"
So,
the
the
> two...
behind
getting
> code)" treatment...
> Andy
> > Hi there,
> weeks I
simply
> > fantastic!!!!
> easy that
distortion
> or
about
> that lil
> > thing...
Urspr
