boe & servo problem
Tad-
Your b2 variable is a byte variable. As such, it can only hold a
value from 0 through 255. On the BS2 and beyond, it's better to
declare and size your own variables than to use b1, w1, etc.
Suggested modification:
i VAR WORD
j VAR BYTE
again:
for i = 500 to 1000
for j = 1 to 5
pulsout 15, i
pause 15
next
next
goto again
Steve
On 29 Oct 01 at 19:17, tadspambait@y... wrote:
> ...i'm attempting to use parallax servos with a BOE Rev. B. I
> hooked up the servos to the 3-pin ports on the BOE, and used
> the following tester code (modified from scott edwards' original):
> again:
> for b2 = 500 to 1000
> for b3 = 1 to 5
> pulsout 15, b2
> pause 15
> next
> next
> goto again
i VAR WORD
j VAR BYTE
again:
for i = 500 to 1000
for j = 1 to 5
pulsout 15, i
pause 15
next
next
goto again
Steve
> again:
> for b3 = 1 to 5
> pulsout 15, b2
> pause 15
> next
> next
> goto again
first off, i should admit that i am a complete newbie, and am
prone to asking silly questions... your indulgance is appreciated
again:
for b3 = 1 to 5
pulsout 15, b2
pause 15
next
next
goto again
the servos have behaved erratically, or not at all.
i have tried several servos & each of the 4 ports (corresponding
to pins 12, 13, 14, 15). i'm fairly confident that i have them
connected properly, so i assume the problem is either with my
code, or with the servos themselves (or with the bs2, but that
seems to be operating correctly with other applications).
does the code look ok? if so, any suggestions on other ways of
testing the servos?
thanks,
tad
them. email parallax. I had that same problem too. The power supply is
giving out too much voltage and it is frying it. parallax should send
you a new one.
from
Tad
(hmmmmm same name. I wonder......)
>howdy folks:
>again:
> for b3 = 1 to 5
> pulsout 15, b2
> pause 15
> next
>next
>goto again
>testing the servos?
>thanks,
>tad
>from the same email address that you subscribed. Text in the Subject and Body
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
the servos are fried!
i guess the bs compiler doesn't throw exceptions?
thanks for your help,
tad
--- In basicstamps@y..., "S Parkis" <parkiss@e...> wrote:
> Tad-
> i VAR WORD
> j VAR BYTE
> again:
> for i = 500 to 1000
> for j = 1 to 5
> pulsout 15, i
> pause 15
> next
> next
> goto again
> Regards,
> Steve
used
original):
> > again:
> > for b3 = 1 to 5
> > pulsout 15, b2
> > pause 15
> > next
> > next
> > goto again
