Need outputs of one to mirror inputs of another
Alright, I'm still figuring out how to work with this code well, so
this may be a simple question.
Basically, I have 2 BS2e's and I am using 6 inputs on one inputting
either a high or low. I need the I/O pins on the "receiving" end to
just respond the same by connecting the 2 by 1 serial line.
The goal is to eventually make this a wireless link. Any help in
structuring the code would be greatly appreciated. Thanks.
to
At first glance, it sounds pretty simple. Read the 6 inputs into a
byte of data, send the data byte serially (serout). At the other end,
read one data byte serially (serin) and output the byte to 6 outputs.
It would be a little easier if you had 8 bits in a group (a whole
byte or input/output port) or could ignore the other two bits (maybe
just don't connect outputs to them?). But its only a little more
code, even if its 6 totally separate bits.
A possible issue is error checking. The simplest thing for checking a
single byte is to just send it multiple times and have the receiver
check all of them to be sure they are the same. If they don't match,
just ignore them and wait for the next transmission, rather than
output any incorrect data. Or send the byte 3 times and "vote" - if 2
of the 3 match (or all three match), use them as output. If all three
are different, ignore them. The chance of all three matching and all
three being wrong are pretty slim, assuming they are corrupted by
random noise. A lot depends on how reliable the link needs to be -
There are even better error checking/correcting techniques that could
be employed, but they tend to get more complex. You could also
acknowledge reception or request retransmission in case of error, but
that would require a two way link and more complexity.
Chuck
