PAK VIII and PWM
Archiver
Hi All,
I bought a PAKVIII that I want to use to generate PWM with a
signal input from the Stamp, but I'm having dificulty trying to
figure out how to use it. Anyone out there with experience in this?
Robert
Robert
richard
Sent: Saturday, October 27, 2001 12:39 PM
Subject: [noparse][[/noparse]basicstamps] PAK VIII and PWM
> Hi All,
> Thanks,
> Robert
I'm using a PAK Va in my program now. It has to update every
program loop, and is relatively slow. I was hoping that the PAK VIII
would be able to do the same job a bit faster.
Robert
--- In basicstamps@y..., "Richard Friedrich" <rfriedrich@a...> wrote:
> I have the pakV and it works great for pwm
> richard
> From: <robert_hiebert@s...>
> To: <basicstamps@y...>
> > Hi All,
this?
> > Thanks,
> > Robert
> > basicstamps-unsubscribe@y...
Subject and
controlling spped of motor with pwm. the inertia of the motor is such that
it cannot instantly change rpm - the PAC is very fast compared to changing a
motor speed. I update my PAC every 20 ms.
richard
Sent: Sunday, October 28, 2001 12:27 AM
Subject: [noparse][[/noparse]basicstamps] Re: PAK VIII and PWM
> Hi Richard,
> Robert
> > richard
> > > Hi All,
> this?
> > > Thanks,
> > > Robert
> Subject and
The idea behind using a PAK-VIII to do PWM is to compute the on and off
times yourself and then set them with the appropriate commands to the PAK.
This is not as convinient as the PAK-V which only generates PWM but it gives
you more control.
For example, suppose you decide you want 100mS total time and 30% "on" time.
You could set the on time to 30mS and the off time to 70mS. 50% at the same
duration would be 50mS on and 50mS off.
Of course, there are many ways to compute PWM. You could look for the
minimum period that would let you express your ratio. So with a 10uS base
you could use 70uS and 30uS to get the same ratio. But then for 50% you
could use 10uS and 10uS (10/20).
Hope that helps.
Al Williams
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: robert_hiebert@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9ZvQc1FjE8nw_I1huu9b60ZItvzMWBiGeistH43rSKE9IycuI2KJP6Du9gIj1bDFu8G3PEfc4PMZ-FzraaJ8HBoH]robert_hiebert@s...[/url
> Sent: Saturday, October 27, 2001 12:40 PM
> Hi All,
> Thanks,
> Robert
I'm quite new at this, and have no previous electronics or
programming background, so I could be way off base. I'm pretty sure
that the serout commands, like debug and the PAK V commands take
longer to execute than the shift in/shift out commands used with the
PAK VIII. I was hoping to reduce my program cycle times a bit with
the PAK VIII.
The lookup tables I'm now using for the PAK V are certainly easy
enough, and one command sets the PAK. Using the VIII may not be
practical, but I'm trying to figure that out.
Robert
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Hi Robert,
off
the PAK.
it gives
> you more control.
30% "on" time.
the same
the
10uS base
you
> Hope that helps.
> Al Williams
> > From: robert_hiebert@s... [noparse][[/noparse]mailto:robert_hiebert@s...]
> > To: basicstamps@y...
> > Hi All,
this?
> > Thanks,
> > Robert
I'm currently developing an application using the Pak8 and a bs2. The
pak8 seems to be self-supporting. Once I've set the registers, my BS2 can
forget about it and do other stuff such as read an a/d among other things.
Then if the need arrises to adjust the PWM output, it simply resets a few
variables of the pak8 and goes on with life.
This project is still in the development phases, however, I have two notes:
1) The oscillator x-tal seems to not work sometimes (bread board, long
wires, I really haven't figured out why?)
2) The 10K resistor between the data line, and the 5V helps!
David Fixemer
One thing to watch for that makes the chip not start up is a "slow rising"
power supply. If your power supply doesn't snap to 5V quickly the chip can
power up in an odd state. The Stamp has a reset controller that prevents
this problem.
To see if this might be your problem, notice if resetting the PAK makes it
recover. If so, consider disconnecting everything from the PAK's reset line
and connecting it to the Stamp's RESET pin. You could also use an RC network
to "stretch" the power on reset pulse or use a cheap reset controller.
On the second point, yep... the output is open collector (so you can tie it
with the input). That means you have to have the pull up resistor specified
or nothing works!
Hope that helps.
Al Williams
> From: Production Technology, L.L.C. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_9WASvgQwIBdevVvizGuK9sbUUszMapI03JjbQUz7xZBf3BODa9K0Hmy3MMRGJO4Uk8nw_pRN6dLuggEBQ]fixemerd@a...[/url
> Sent: Monday, October 29, 2001 7:12 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: PAK VIII and PWM
> Stampers,
> two notes:
> David Fixemer
Never mind the last email, just got yours, thanks for the answer!
David Fixemer
>consider disconnecting everything from the PAK's reset line and
Just a note on this: Only the original BS2 brings the active low
reset signal as an output (or input) to pin 22 on the carrier board.
The 'SX based Stamps do not; pin 22 is input only.
