serial input buffer
I apologize for my electronic knowledge, I am only a mechanical engineer :
). I have a serial device that sends data about every second. How can I
store this serial data somewhere so that I can do other tasks with my BS2
and periodically check this serial 'buffer'. It seems as though I am not
getting this serial data because my stamp is performing other tasks. I
don't want to tie up my stamp just looking for the data to come across.
Thanks, Dan
Thanks, Dan
(http://www.parallaxinc.com/downloads/SXTech/IO%20Control%20with%20the%20SX.
PDF). This uses an SX chip to do what you describe.
Unfortunately, we don't commerically produce the SSIB and neither does
Parallax. If you don't have the means to make one yourself and it looks like
it would do what you want, contact me off list and I'll see what we can do
for you.
Jump to page 89 to read about the SSIB.
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: daniel.d.dangremond@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0pzQCce_anLzIMpXw46s0CEpKiq0QdBPSvlo-DlqYs7_T9GmJSFPYFyvC3qxogPuiSsYugxWxZv-WtRlzUT8z_0Pi7NJuw]daniel.d.dangremond@j...[/url
> Sent: Wednesday, October 24, 2001 9:35 AM
> Subject: [noparse][[/noparse]basicstamps] serial input buffer
> Thanks, Dan
> from the same email address that you subscribed. Text in the
do with them is make the serial input a priority. My suggestion is that you
look for the serial input and once you've got it, go take care of one of your
other activities (or as many as you can squeeze into the time between serial
bursts). You should probably use the Timeout parameter on SERIN in case you
serial data stops coming.
-- Jon Williams
-- Parallax
In a message dated 10/24/01 9:39:02 AM Central Daylight Time,
daniel.d.dangremond@j... writes:
reads and stores all incoming data in a First In First Out ordering. The
stamp then reads the data out of the buffer at its leisure.
One premade system is the RAMpack B from :
http://www.solutions-cubed.com
In the manual look at application note 55.
(Note: The stamp controls when the device can write into the fifo. This
circuit requires that the stamp turns of the writing ability inorder to
read the data from the fifo. during this time the device cannot write new
data to the fifo.)
Joshua
--On Wednesday, October 24, 2001 10:34 AM -0400 daniel.d.dangremond@j...
> Thanks, Dan
Parallax has a plausible story for getting around the issue (any self-
respecting micro should have this functionality on board). It has me
ready to move to a different platform.
Anyway, there's a chip, the RB509, that implements a 32 byte serial
buffer. Works great. Easy to use. You can find it on:
http://www.protean-logic.com
They have an app-note on hooking it up to the BS2.
Hope this helps.
so to be able to buffer the input for fast data collection. The setup looks
like this
SERIN pin,baud,[noparse][[/noparse]SPSTR L] where L can be between value or variable between 1
and 128. The data is collected in ram locations 0 to 127 and can be read with
the GET command. This is very helpful when reading gps input data.
Chuck
StampW program help.
> The BS2p now has a statement, SPSTR L, that can be added to the SERIN command
> like this SERIN pin,baud,[noparse][[/noparse]SPSTR L] where L can be between value or variable
> between 1 and 128. The data is collected in ram locations 0 to 127 and can be
> read with the GET command. This is very helpful when reading gps input data.
> Chuck
miked@t... writes:
You are right. It is not in the 2.0 manual but is discussed in the new editor
help files.
Chuck
> That one seems to missing from the 2.0 manual. It is in the
> command
> looks
> variable
> can be
> data.
> > Chuck
