Number output to an LCD
Gentlemen,
I need your help again.
I can display all the text in the world to the LCD, but it doesnt like
variables (especially with numbers)
I have looked for a conversion instruction, but was unable to find one. I
need to convert a 10 bit ADC to display it on the LCD. Eventually I will
also need to do math on it, but FP numbers are difficult in PBasic.
Mark
Mark
string of characters. It's not too tough -- you can use a loop with the DIG
operator to get the individual digit value in each place, then add "0" (ASCII
48) to convert it to a character -- then send it to the LCD.
Here's a code fragment that assumes your number is in a variable called myNum.
WriteNumber:
FOR x = 4 TO 0 ' scan 5 possible digits
in number
char = myNum DIG x + "0" ' convert digit to ASCII code
GOSUB LCDwrite ' write to LCD
NEXT
RETURN
-- Jon Williams
-- Parallax
In a message dated 10/24/01 8:19:22 AM Central Daylight Time,
madams@a... writes:
Now what about dividing a 10 bit number by 0.0733
Mark
From: jonwms@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yk9_B4RRV9s9GBLGY-Fierq1lwt8-bS-T3SSRWALJPjfpEqbrnplSV6AroojyPT2XnoDv0_NNA]jonwms@a...[/url
Sent: Wednesday, October 24, 2001 9:05 AM
Subject: Re: [noparse][[/noparse]basicstamps] Number output to an LCD
LCDs only display charcters, so to display a number, you must convert it to a
WriteNumber:
in number
NEXT
RETURN
-- Jon Williams
-- Parallax
madams@a... writes:
from the same email address that you subscribed. Text in the Subject and Body
madams@a... writes:
Dividing by 0.0733 is the same as multiplying by 13.6426. The BASIC Stamp
has an operator called star-slash (*/) that can be used to multiply
fractional values. The fractions are expressed in 1/256. In the case above,
13.6426 * 256 = 3492. Your code, then, is this:
newVal = oldVal */ 3492
You will have to deal with possible rounding and overflow errors. It would
be best to write some test code and DEBUG the results to make sure they're in
line with what you expect.
-- Jon Williams
-- Parallax
PS: Tracy Allen is the undisputed best when it comes to Stamp math and
dealing with high-precision values. You really should visit his site:
http://www.emesys.com/BS2index.htm
site) but if you could tolerate 5% error a quick approach is just
multiply by 13.
ACJacques
Mark Adams wrote:
> That is exactly what I was looking for, thanks!
> Mark
> From: jonwms@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NCX4Svf6gA49C9mSheu1RxswrjAKmNCEbJbPNTUZCO4aJLXUxSFq91KRcRmfkPpUObCjFt3kWhs]jonwms@a...[/url
> WriteNumber:
> in number
> NEXT
> RETURN
> -- Jon Williams
> -- Parallax
> madams@a... writes:
PAK-I, II, and IX all of which do floating point math.
http://www.al-williams.com/awce/pak1.htm
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: Mark Adams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1AAIwdRKbCWoRWlT2AdyUroyAF3djF2MCHJXd0oloE_E2jzIRVnfGLClAfysrV8Tzho2RBCASD-t2Q]madams@a...[/url
> Sent: Wednesday, October 24, 2001 9:14 AM
> To: 'basicstamps@yahoogroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] Number output to an LCD
> Mark
> From: jonwms@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5cHLhWf_5rwKhcZmXJpel0ZtXObKeAi8DCiE3Sh_cPAGyLjkd8nuLRAoyPd2g6D5so9KWdM]jonwms@a...[/url
> convert it to a
> with the DIG
> add "0" (ASCII
> called myNum.
> WriteNumber:
> possible digits
> in number
> ASCII code
> NEXT
> RETURN
> -- Jon Williams
> -- Parallax
> madams@a... writes:
> find one. I
> Eventually I will
>madams@a... writes:
>-- Jon Williams
>-- Parallax
Thanks for the boost, Jon!
The best precision easily comes from the ** operator. It expresses
fractions in units of 1/65536, which is in general more accurate than
1/256. But ** can only do fractions between zero and one, so it
takes two steps on the Stamp:
newVal = (oldval * 13) + (oldVal ** 42111)
0.6425648 * 65536 = 42111
that is to say, 42111/65536 is close to 0.6425648, within better than
4 decimal places. With a ten bit number for oldval, it is not going
to overflow. That is, the maximum value 1024/0.0733 is 13970, less
than one word in value. The new value has more significant digits
than the old value, so you could probably round off the last digit.
The ** operator gives you the extra precision to allow accurate
rounding.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
