midi joystick interphase
Has anyone had any experience interphasing a midi computer joystick with a
stamp? I think they plug into the midi port of a computer's sound card so I
suppose it sends midi commands that could be interpreted by the stamp fairly
easily.
Stewart
Date: Tuesday, October 23, 2001 15:27:03
Subject: RE: [noparse][[/noparse]basicstamps] Re: LCD compatibility for BASIC STAMP 1.....
This is a great link, but I have to be honest, I've never built a power
supply, I'm just interested in knowing basically how it is done? Is it
directly from a power supply or from other components in a given circuit you
are building? Anyone else?
(The list has been awfully quiet today, so I don't mind a fairly worthless
post [noparse]:)[/noparse]
TIA,
John Walton
From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YWc6zuIHwaEQxi1mluaw3ZpL4ntRgxIhF-EMotWEN2nEPKTNGPFSR35nYqzXM3nrQN3_rHkxHX8Ut3I]kolalde@h...[/url
Sent: Tuesday, October 23, 2001 4:47 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: LCD compatibility for BASIC STAMP 1.....
http://www.epanorama.net/psu.html#lowvoltage
John Walton wrote:
> I've seen this suggestion before, about the negative supply voltage on
> LCD's. I'm sorry, but I have to ask: How the heck does one supply
> -5v? Sorry for the stupid question, but I don't know!
easily.
Stewart
TIA,
John Walton
Oh, I am working in similar thing! I found Nuts & Volts Feb 2001 have an
article got a closely related example. A game joystick used to interface
with BS. Hope it is useful for you.
John Leung
Sent: Wednesday, October 24, 2001 5:49 AM
Subject: [noparse][[/noparse]basicstamps] midi joystick interphase
I
fairly
> easily.
> Thanks,
> Stewart
> From: basicstamps@yahoogroups.com
you
> TIA,
> John Walton
> From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ETGGfMQXxlsUAWY7yPpEAb_DRP_6u2ur6xqLq0J3ffoO4yw9wkyuB5FICgxBUw1HvCkKFH8ixOI]kolalde@h...[/url
have the article. But I did find a pinout description of the 15 pin D-sub
connector used by joysticks at http://eleceng.ukc.ac
uk/hwb/co_GameportPCMidi.html
If the joystick x and y ouputs are a 0 - 5volt output from potentiometers,
then I suppose a DA chip could be used to get a numerical position value to
the stamp, I'm not sure, I'm new at this. Can you tell me briefly what N&V
says about this?
Thanks, Stewart
Date: Tuesday, October 23, 2001 08:58:35 PM
Subject: Re: [noparse][[/noparse]basicstamps] midi joystick interphase
Dear Stewart
John Leung
I
fairly
> easily.
> Thanks,
> Stewart
you
> TIA,
> John Walton
> From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w4kK3zeTFk7u3H9TTDVofh9XrID7DQtQncHAVY2gGEKkGzd-raWggG_57nQgkB-yysrNsgkx6un1cbs]kolalde@h...[/url
each end of a TWS-434, RWS-434 pair to send the signal from either a
gamepad or joystick. My main problem is with the gamepad itself. I
have hooked it up to a breadboard with a stand alone power supply
according to those pinouts, but I don't get the proper output
voltages on the pins. Let me know what kind of success you have.
Thanks.
-John
--- In basicstamps@y..., "Stewart Mayer" <stewlist@k...> wrote:
> Unfortunately I have only recently been receiving Nuts & Volts so I
don't
pin D-sub
potentiometers,
value to
what N&V
> says about this?
> Thanks, Stewart
> From: basicstamps@y...
> To: basicstamps@y...
> Dear Stewart
have an
interface
> John Leung
> From: Stewart Mayer <stewlist@k...>
> To: <basicstamps@y...>
joystick with a
card so
> I
stamp
> fairly
> > easily.
> > Thanks,
> > Stewart
1.....
power
Is it
circuit
> you
worthless
> > TIA,
> > John Walton
> > From: Kevin Olalde [noparse][[/noparse]mailto:kolalde@h...]
1.....
voltage on
supply
> > basicstamps-unsubscribe@y...
Subject and
Subject and
Subject and
Subject and
JoyX CON 4 ' x-axis pot reading
JoyY CON 5 ' y-axis pot reading
BtnX VAR In6 ' x-axis button
BtnY VAR In7 ' y-axis button
JoyBtns VAR InB
joyXval VAR Word ' joystick x reading
joyYval VAR Word ' joystick y reading
xAxis VAR Nib ' target axis
yAxis VAR Nib
btns VAR Nib ' button status
Crosshair:
btns = ~JoyBtns >> 2 & %0011 ' read buttons (1=down)
BRANCH btns,[noparse][[/noparse]ShowTarget,ShowSmile,Main,Main]
ShowTarget:
GOSUB ReadJoyStick
xAxis = joyXval/(JoyXMax / 5) MAX 4 ' crosshair column
yAxis = joyYval/(JoyYMax / 7) MAX 6 ' crosshair row
FOR col = 1 TO 5
LOOKUP yAxis,[noparse][[/noparse]$01,$02,$04,$08,$10,$20,$40],d7219
IF ((col-1) <> xAxis) THEN DrawColumn ' draw crosshair
d7219 = $7F
DrawColumn:
SHIFTOUT Dpin,Clock,MSBFirst,[noparse][[/noparse]col,d7219]
PULSOUT Load,3
NEXT
GOTO CrossHair
ReadJoyStick:
HIGH JoyX ' discharge RC caps
HIGH JoyY
PAUSE 5
RCTIME JoyX,1,joyXval ' read x axis
RCTIME JoyY,1,joyYval ' read y axis
RETURN
I hope this is useful for you. In fact, you can download the whole BS2 file
from http://www.nutsvolts.com/toc_Pages/feb01toc.htm
John
Sent: Wednesday, October 24, 2001 12:53 PM
> Unfortunately I have only recently been receiving Nuts & Volts so I don't
to
N&V
> says about this?
> Thanks, Stewart
> Dear Stewart
> John Leung
a
so
> I
> fairly
> > easily.
> > Thanks,
> > Stewart
> you
worthless
> > TIA,
> > John Walton
> > From: Kevin Olalde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aoYDSK-91vT1SLb7BzREqt2k21A7t-WLC-tPVcXC371uKE5vg4wvx8IBmYbsPWlzNEDjrxS5dA]kolalde@h...[/url
