How to dim a TL
Archiver
Does anyone knows how to dim TL (Tube Light) by using the stamp?
of incandescent lamps, you could use a "DC Controlled Dimmer", 0-10V DC
proportionally controls either 24, 110 or 240V AC. I haven't used one but I saw
it on Jameco's web site, part #128901. www.jameco.com . Good luck.
Smalcor <Smalcor.AmusementsProducts@1...> wrote: Does anyone knows how to
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
> I'm not sure what type your taking about, but if it's the kind that
has a series of incandescent lamps, you could use a "DC Controlled
Dimmer", 0-10V DC proportionally controls either 24, 110 or 240V AC.
I haven't used one but I saw it on Jameco's web site, part #128901.
What I mean is the fluorisent light.
that
AC.
I want to be able to regulate the light in a aquarium so, that it
looks like the sun is comming up in the morning and going down in the
afternoon. The light in an aquarium is usualy fluorisent light. I
know it must be able to dim fluorisent light, but I don't know how to
do this. If it's possible I would also like to measure PH value of
the water.
>that
>AC.
>the water.
In general fluorescent lamp dimming is not an easy task. Usually special
dimming ballasts are required. Although I've not used it, you may want to
take a look at the IR2159 or the IR21591 Dimming ICs from International
Rectifier [noparse][[/noparse] http://www.irc.com ]. Punch the LIGHTING button, then FLUORESCENT.
Please be advised this too is not a simple solution.
Bruce Bates
www.misty.com/people/don/f-lamp.html
On Wed, 24 Oct 2001 08:44:00 -0000 Smalcor.AmusementsProducts@1...
writes:
> that
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/web/.
ballast from Lutron some time ago and they work great, 0-10V DC gives me control
from about 10%-100% output. I just looked on Advance Transformer web site and
found they have a new series of electronic ballast, the "Mark VII", that can
control all the way down from 1% to 5%-100% depending on the lamp type. I may
buy a couple of them to replace the units I own. I doubt that you will find them
at a home center and will likely need to purchase them from either a specialty
lighting center or an electrical wholesale house, you can get a supplier from
Advance.
odrew@j... wrote:
Do You Yahoo!?
