motor-mind B
What is the best way to run two motor-mind B's (serial H bridge motor
drivers) from a single supply. Since both units respond to the same
code there has to be a way to set up an identification between the
two. The digital commands and motor power will share the same wires.
from one module into one Stamp pin and you need one pin for a brake -- so 4
pins total for 2 modules.
