Stampworks experiment #23 used with App II
Hi Al(l),
I was trying to get familiar with Shiftout and Shiftin commands. I
thought experiment #23 was a good example to work with. The 74x595
was hooked up to the App-II (which is a programmed PIC16F873) instead
of the BS2. I have attached two basic codes (the one with the "a" in
the end is the orginal from stampworks). The LED flashes only forward
and doesn't flash backwards. Why is that happening? Any response will
be appreciated.
Here's the code from exp #23:
' File: 74x595.BS2
' Use three lines to control eight with a 74x595 shift register
D_out CON 0 ' serial out (74x595.14)
Clock CON 1 ' shift clock (74x595.11)
Latch CON 2 ' output latch (74x595.12)
DlyTm CON 100
pattern VAR Byte ' output pattern
Initialize:
LOW Latch ' make output and keep low
pattern = %00000001
GoForward:
GOSUB Out595
PAUSE DlyTm ' put pattern on 74x595
pattern = pattern << 1 ' shift pattern to the left
IF pattern = %10000000 THEN GoReverse ' test for final position
GOTO GoForward ' continue in this direction
GoReverse:
GOSUB Out595
PAUSE DlyTm
pattern = pattern >> 1
IF pattern = %00000001 THEN GoForward
GOTO GoReverse
END
Out595:
SHIFTOUT D_out,Clock,MSBFirst,[noparse][[/noparse]pattern] ' send pattern to 74x595
PULSOUT Latch,3 ' latch outputs
RETURN
Here's the how I modified the code to take up the upper 3 pins of the
PIC:
' File: 74x595.BS2
INCLUDE "modedefs.bas"
D_out CON 5 ' serial out (74x595.14)
Clock CON 6 ' shift clock (74x595.11)
Latch CON 7 ' output latch (74x595.12)
DlyTm CON 500
pattern VAR BYTE ' output pattern
Initialize:
Low Latch ' make output and keep low
pattern = %00000001
GoForward:
GoSub Out595
Pause DlyTm ' put pattern on 74x595
IF pattern = %10000000 Then GoReverse ' test for final position
GoTo GoForward ' continue in this direction
GoReverse:
GoSub Out595
Pause DlyTm
IF pattern = %00000001 Then GoForward
GoTo GoReverse
End
Out595:
ShiftOut D_out,Clock,MSBFirst,[noparse][[/noparse]pattern] ' send pattern to 74x595
'ShiftOut PORTB.0,PORTB.1,MSBFirst,[noparse][[/noparse]pattern]
PulsOut Latch,10 ' latch outputs
Return
Sincerely,
RP
be appreciated.
' File: 74x595.BS2
DlyTm CON 100
Initialize:
pattern = %00000001
GoForward:
GOSUB Out595
GoReverse:
GOSUB Out595
PAUSE DlyTm
GOTO GoReverse
END
Out595:
RETURN
PIC:
' File: 74x595.BS2
DlyTm CON 500
Initialize:
pattern = %00000001
GoForward:
GoSub Out595
GoReverse:
GoSub Out595
Pause DlyTm
GoTo GoReverse
End
Out595:
Return
Sincerely,
RP
of the BS2. For those not familiar with the App-II, it can be found
at this site: www.al-williams.com/awce/app2.htm. The first code is
the original code. The second was modified to be compiled by Pic
Basic Pro. The LED flashes only forward and doesn't flash backwards.
be appreciated.
' File: 74x595.BS2
DlyTm CON 100
Initialize:
pattern = %00000001
GoForward:
GOSUB Out595
GoReverse:
GOSUB Out595
PAUSE DlyTm
GOTO GoReverse
END
Out595:
RETURN
PIC:
' File: 74x595.BS2
DlyTm CON 500
Initialize:
pattern = %00000001
GoForward:
GoSub Out595
GoReverse:
GoSub Out595
Pause DlyTm
GoTo GoReverse
End
Out595:
Return
Sincerely,
RP
