Slick way to see if the stamp is still working??? — Parallax Forums
edited 2001-10-19 23:49 in General Discussion
My current stamp project uses a stamp to sleep for a long period of time (3
hours), wake up, open a solenoid for about 10 seconds, then sleep again. My
question is this:
Is there any way to tell when I check the stamp while it is running if
everything is still ok? This project runs off of batteries, so I need to
conserve every bit of power I can. Otherwise I would just put a LED on the
project, that could be my indicator.
Anyone have a slick idea on how to check to make sure everything is still
running, short of waiting up to 3 hours to see if the solenoid opens?
John
    edited 2001-10-18 21:16
    That's not too bad of an idea... I'm hoping for one even slicker though.
    This device needs to run for weeks or months on a 6v lantern battery.. I
    know I'm asking the impossible so to speak. I don't know much about them,
    but I bet an interrupt would come in handy right about now!?
    Thanks for the input,
    John
    Subject: RE: [noparse][[/noparse]basicstamps] Slick way to see if the stamp is still
    working???
    How about sleep for shorter period say 30 seconds, wakeup pulse out to an
    LED for 1/2 a second then go to sleep again. This should save considerable
    battery power and still give an indication that it is still alive.
    edited 2001-10-18 22:03
    Modify this idea with the addition of a normally open
    pushbutton. Sleep for shorter intervals - decide what
    the user can live with, since this test would be
    infrequent - and between intervals, check the
    pushbutton. If the pushbutton is on, turn on the light
    until it is released before returning to the normal
    cycle of sleeping, or keep the light on for a set time
    such as 3 to 5 seconds, and then make up for the lost
    time between your main operations to retain the
    multi-hour timing to the second.
    Bob Pence
    > lantern battery.. I
    > about now!?
    > John
    > stamp is still
    > working???
    > is still alive.
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Make a great connection at Yahoo! Personals.
    http://personals.yahoo.com
    edited 2001-10-18 22:11
    > to conserve every bit of power I can. Otherwise I would just put a
    > LED on the project, that could be my indicator.
    Put a push-button in series with your LED. When your finger is on
    the button the LED will blink off every couple of seconds from the
    watchdog timeout. I would put in a transistor with a pullup on the
    base (all powered via the push-button) and have the I/O pin set to a
    0 so that it was normally off and blinked on. Mostly because it
    looks better, but it also uses less current.
    Steve.
    Steve Baldwin Electronic Product Design
    TLA Microsystems Ltd Microcontroller Specialists
    PO Box 15-680, New Lynn http://www.tla.co.nz
    Auckland, New Zealand ph +64 9 820-2221
    email: steveb@t... fax +64 9 820-1929
    What is the application?
    If the application is outdoors, you could put a solar panel on the
    stamp and use a rechargable battery. Do the LED blink thing like
    the other guy mentioned to see if it is actually running, and the
    solar to keep the battery up indefinitely.
    Doug
    > time (3 hours), wake up, open a solenoid for about 10 seconds, then
    > sleep again. My question is this:
    > still running, short of waiting up to 3 hours to see if the solenoid
    > opens?
    > Thanks,
    > John
    > from the same email address that you subscribed. Text in the Subject
    > and Body of the message will be ignored.
    edited 2001-10-19 00:13
    Hi John,
    Or, couple a "push to test" pushbutton to the reset input, so when
    the user presses it, the system wakes up immediately and runs the
    tests and then indicates the results even in morse code or something
    like that on an led or piezo speaker. I don't know how much you want
    in the way of system test results.
    BS2 reset pin
    ||---o----/\/\--+5
    Stamp P0
    o
    \o N.O button
    com, Vss
    Test for P0 low at reset. That is as close as the Stamp gets to an
    interrupt. True, this will disrupt your 3 hr sleep cycle, but
    presumably the user will not test it very often. You could also use
    this as a means to set the time until the next solenoid activation,
    by holding the button down for an interval proportional to the
    required time.
    -- Tracy
    >Bob Pence
    >> lantern battery.. I
    >> about now!?
    > > John
    edited 2001-10-19 05:34
    It is definitely outdoors, and I've thought about the solar/rechargeable
    solution. I guess I just haven't taken the time to figure it out... My
    initial concern would be the cost of the battery. The stamp takes almost
    zero power while it is sleeping, and my relay/solenoid only fires a maximum
    of every 3 hours, so that doesn't use much power either. Anyone done a
    project with a stamp and a solar panel like I'm discussing?
    TIA,
    John Walton
    >Doug
    > > --snip--
    edited 2001-10-19 05:41
    Tracy,
    Would this prove the stamp was running when I first went to check it? I
    may be missing something here, but if I reset it, I don't actually know if
    everything was a-ok when I went to test it. I would know it still works,
    but I wouldn't know how it was doing to begin with. Thank you for the
    schematic though, it's very helpful to us newbies [noparse]:)[/noparse]
    Thanks again,
    John
    At 04:13 PM 10/18/01 -0700, you wrote:
    >Hi John,
    > BS2 reset pin
    ||---o----/\/\--+5
    > Stamp P0
    o
    > \o N.O button
    > com, Vss
    >required time.
    > -- Tracy
    > >Bob Pence
    > >> lantern battery.. I
    > >> about now!?
    > > > John
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2001-10-19 23:13
    How long does the solenoid stay pulled in and how much current
    does it require? You might be able to use a very large capacitor as
    the power source, maintained by the solar panel. No worries for a
    battery going defective. Capacitors will last for *years* with no
    maintenance if they are not over charged. A good source is from
    an old power supply and find the biggest you can find. I have some
    out in the barn with a 24000 microfarad at 50 VDC. If you charge
    this with a 12 volt solar panel, and use a very efficient regulator,
    you may get hours of operation from the dischagre of the capacitor.
    I will do some experimenting with a circuit I'm working on with 3
    sonar modules and see how log it will run on a charge.
    Let you know what happens later.
    Doug
    > solar/rechargeable solution. I guess I just haven't taken the time to
    > figure it out... My initial concern would be the cost of the battery.
    > The stamp takes almost zero power while it is sleeping, and my
    > relay/solenoid only fires a maximum of every 3 hours, so that doesn't
    > use much power either. Anyone done a project with a stamp and a solar
    > TIA,
    > John Walton
    > >stamp and use a rechargable battery. Do the LED blink thing like the
    > >other guy mentioned to see if it is actually running, and the solar
    > >Doug
    > > > of time (3 hours), wake up, open a solenoid for about 10 seconds,
    > > > then sleep again. My question is this: --snip--
    I connected the stamp2sx, and all three sonar modules to the
    24000 uF capacitor and charged it with 12 v. it runs three sonar
    modules, pinging all three one behind the other, 150ms apart. It
    will ping 7 to 8 more times after power is removed. Keep in mind
    that the sonar modules require nearly 1 amp of current (for a very
    short time) during the actual ping. If your solenoid isn't real
    demanding, and it don't have to remain pulled for too long, this may
    be ok. The stamp will run quite awhile in sleep mode.
    Hope this helps. . .
    Doug
    > maintenance if they are not over charged. A good source is from an
    > old power supply and find the biggest you can find. I have some out
    > in the barn with a 24000 microfarad at 50 VDC. If you charge this
    > with a 12 volt solar panel, and use a very efficient regulator, you
    > Doug
    > > to figure it out... My initial concern would be the cost of the
    > > battery. The stamp takes almost zero power while it is sleeping, and
    > > my relay/solenoid only fires a maximum of every 3 hours, so that
    > > doesn't use much power either. Anyone done a project with a stamp
    > > TIA,
    > > John Walton
    > > >Doug
    > > > > seconds, then sleep again. My question is this: --snip--
    > > Subject and Body of the message will be ignored.
