Flame simulator — Parallax Forums
Flame simulator
edited 2001-10-19 19:47 in General Discussion
I would like to realalisiticly simulate a flame in a fireplace using a BS 1 or
BS 2.
For now I would just be using super bright LED's, maybe one yellow and two red's
connected to three output pins.
I would like the LED's to flicker independently, each for random length of time
and to vary from dim, not off, to bright.
Has anyone done something similar and have any code to share?
Thanks in advance,
Tom
    edited 2001-10-17 14:13
    I've not actually tried this, but having seen other flame simulator circuits,
    you may consider using the PWM command (with a MIN value for the forward
    voltage of the LEDs) to drive the LEDs and RANDOM to create the random
    values. You may need to seed RANDOM differently for each LED.
    -- Jon Williams
    In a message dated 10/17/01 7:28:55 AM Central Daylight Time,
    scheibl@p... writes:
    > or BS 2.
    > red's
    > time and to vary from dim, not off, to bright.
    edited 2001-10-17 15:17
    I know several people who do this with PAK-V ICs but I don't have their
    code. The PAK-V lets you drive all the LEDs at the same time instead of
    switching between them one at a time.
    http://www.al-williams.com/awce/pak5.htm
    Al Williams
    AWC
    * Floating point A/D
    http://www.al-williams.com/awce/pak9.htm
    > From: Thomas R. Scheibl [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QwIyHOa2q8dO9d1WI4K-mBvPTH1Vi1eLmb2AT5zonrTKJc2QAbdDPkqbZKupjIk_r2n8wVIMlCT0]scheibl@p...[/url
    > Sent: Wednesday, October 17, 2001 7:26 AM
    > Subject: [noparse][[/noparse]basicstamps] Flame simulator
    > using a BS 1 or BS 2.
    > length of time and to vary from dim, not off, to bright.
    > Thanks in advance,
    > Tom
    > from the same email address that you subscribed. Text in the
    edited 2001-10-17 16:43
    There is a very low tech solution done in museums and theaters. You
    can make a simple translucent cover (wax paper on some steel wire
    skeleton) and under it a red light, a fan with some streamers. The
    effect is very good. You can replace the fand with a motor with some
    vertical strips (wavy shapes)that turn at different speeds!
    Just a thought, and it may not work at all for you.
    Al
    and two red's
    > Thanks in advance,
    > Tom
    edited 2001-10-17 17:04
    Hello,
    I was trying to do the same,, to make a flickerflame ,
    just like in Disneyland in some cave games.
    I have to tell you that with Basic Stamp is too
    complicated because the BS1 or 2 is a microcontroller
    with a basic language interface that can only
    interprate one command at a time.
    To simulate a flame you need to have at least 2
    independient signals (maybe a sin or cos math
    function). The BS has a command that can generate
    this kind of signal but just 1 at a time,, that means
    that you will have first a flame in one led and then
    this led goes off and then you will have a flame in
    the other led... this doesnt work. A solution for
    this is to use another integrated circuit working with
    the BS2 but it will be a little complicated.
    I did this using another microcontroller but this
    micro is for advance users. This micro is a real micro
    for industrial use. The micro is the Motorola HC12 or
    HC11 (both works). This micro can generate the same
    signal but you can get as much as 32 (depending on the
    package of the micro) signals at the same time and
    each signal can be diferent from the other.
    This is the only and easy way to do it,,,
    If you need more info just tell me!!
    Alex
    > and theaters. You
    > some steel wire
    > streamers. The
    > a motor with some
    > speeds!
    > Al
    > a fireplace
    > maybe one yellow
    > and two red's
    > each for random
    > bright.
    > code to share?
    > > Thanks in advance,
    > > Tom
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Make a great connection at Yahoo! Personals.
    http://personals.yahoo.com
    edited 2001-10-17 17:15
    Um.... you can have two Stamp outputs on at the same time. Whats to prevent
    you from turning one one "flame," waiting a bit, turning another "flame" on,
    then turning them both off?
    edited 2001-10-17 19:27
    Also, you can add capacitors and resistors to the outputs of the stamp, and
    drive the LEDs with this. (you may need do drive each circuit through a
    transistor, since some of these ideas could pull more current than the
    stamp is able to sink/source.)
    The light will only get as bright as is driven by the PWM, then slowly
    fade. The stamp could drive the pin low to make the LED fade quickly.
    You can source current to the LEDs through the RC circuit, so the LEDs will
    slowly fade up, and the stamp would drive the RC circuit low to dim the
    leds.
    Note, when you want the RC circuit to take over, the stamp will have to go
    high impedance (input) for that pin.
    You could also have a bunch of RC circuits for each LED. the stamp can mux
    which RC circuit is driving the LED. with different R and C for each
    circuit, the LEDs will fade up/down at different rates.
    so many ideas, so little time.
    hope some of these help,
    joshua
    --On Wednesday, October 17, 2001 11:15 AM -0500 Rodent
    > prevent you from turning one one "flame," waiting a bit, turning another
    > "flame" on, then turning them both off?
    edited 2001-10-18 05:53
    Since this is probally for halloween. Here is some quick and dirty
    solutions.
    Are you trying to make a bulb flicker like a flame?"Asynchronous Lamp
    Flickerer" http://www.phantasmechanics.com/alf.html If so you can use a
    florescent starter. Or rig up a dimmer with a capicator.
    http://www.phantasmechanics.com/fpilot.html
    There is also ways to simulate a fake flame with lights on a silk cloth,
    moved by a fan. http://www.hiddenmickeys.org/Disney/Imagineering/Fire.html
    http://www.employees.org/~joestone/Halloween/Html/silkflame.htm
    http://hometown.aol.com/celynn/page1.html
    MonsterList Of Links to Halloween Do-It-Yourself Projects, where i got the
    links
    http://markbutler.8m.com/monsterlist.htm
    edited 2001-10-19 14:50
    Thanks to all who replied. The idea of simulating a flame, at first, I thought
    would be easy, but now I see it can get quite involved. The use was to be
    twofold, pumpkin at holloween, using LED's, and artificial fireplace at
    Christmas, using optisolators to drive incandescent bulbs.
    I appreciate all of your advise, and now that it's fall time, I will go to my
    workshop and experiment.
    Thanks to all,
    Tom
    edited 2001-10-19 15:22
    Thomas: There was an N&V article on making a flashing pumpkin using 2
    radioshack blinking leds tied in parallel as I recall. The idea was that the
    2 leds would flash at differant random rates, and make a flickering flame
    effect.
    I tried it myself and had no luck however.
    -Kerry
    thought would be easy, but now I see it can get quite involved. The use was
    to be twofold, pumpkin at holloween, using LED's, and artificial fireplace
    at Christmas, using optisolators to drive incandescent bulbs.
    my workshop and experiment.
    >Thanks to all,
    >Tom
    >from the same email address that you subscribed. Text in the Subject and
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Kerry Barlow
    p.o. box 21
    kirkwood ny
    13795
    607-775-1132
    edited 2001-10-19 15:54
    Stamp is overkill. Wire 2 555's as slow oscillators
    Connect 2 led's back to back between the outputs of the 555's. Here's
    what happens:
    Both 555's ON - both led's OFF
    Both 555's OFF - both led's OFF
    555 #1 ON, 555 #2 OFF - led 1 ON, led 2 OFF
    555 #1 OFF, 555# 2 ON - led 1 OFF, led 2 ON
    The led's alternate pseudo- randomly, with "off" periods. Use
    optoisolators and triacs or solid state relays to drive red and
    orange incandescant bulbs. Adjust frequency and duty cycle of each
    555 for desired effect. I have built this circuit and it works. You
    can use additional, dimmed, red and incandescant lamps to soften the
    flickering effect. The "flickering" lamps can also be dimmed to
    further enhance the realism of the effect. Using surplus parts this
    can all be done for less than the cost of one BS2.
    first, I thought would be easy, but now I see it can get quite
    involved. The use was to be twofold, pumpkin at holloween, using
    LED's, and artificial fireplace at Christmas, using optisolators to
    will go to my workshop and experiment.
    > Thanks to all,
    > Tom
    edited 2001-10-19 19:43
    Hi Tom,
    I didn't see this mentioned specifically in the other replies, so I
    thought I would bring it up. I think the way I would approach this
    would be with a tight loop and the RANDOM function. That would
    require several LEDs on different pins. Let's assume
    ' 8 leds on 8 pins, P8 to P15
    x var word
    dirh=$ff
    loop:
    random x
    outh=x
    pause 1
    goto loop
    The number of leds lit at a time is random, so flickering is the
    result. The pause command slows it down a bit, but I am not sure
    what delay would give the best effect. Without a pause, the loop on
    the BS2 would run about 1500 times per second, which might make the
    overall flicker rate too fast. You could also fiddle with the pause
    value to make it random:
    pause x.nib3
    Just an untested thought.
    -- best regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
    >a BS 1 or BS 2.
    >and two red's
    >Thanks in advance,
    >Tom
    >was to be twofold, pumpkin at holloween, using LED's, and artificial
    >fireplace at Christmas, using optisolators to drive incandescent bulbs.
    Maybe go and search out the old Popular Electronics / Radio Electronics
    website (www.gernsback.com) and see if they have any old articles on line
    for this. I saw it done in an old magazine article: they used 4 astable
    oscillators all running at slightly different frequencies, with the outputs
    summed to the control input of whatever lamp driver they were using. It
    looked inexpensive and might do what you need.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 17 years of Engineering Innovation (1984 - 2001)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
