Bs1 pwm
Archiver
Stampers,
How have you found the PWM output on the BS1?
How accurate is it?
We have an app weher we need to generate 0-5v in 255 steps do PWM seems to
fit the bill perfectly. We will monitor that volatge with an input that has a
100k input impedance. That should not apply to much of a load I would hope!
Stocky
How accurate is it?
Stocky
Further to the message below, we have tried it but it seems to vary, as in
the steps dont seem to be the same, eg for exampel if a step is supposed to be
0.0196v the steps don't follow the pattern of: 0.0196, 0.0392, 0.0588, etc
Is this just an error/factor of the PWM command?
Sent: Wednesday, October 17, 2001 9:15 PM
Subject: BS1 PWM
Stampers,
How accurate is it?
We have an app where we need to generate 0-5v in 255 steps do PWM seems to
Stocky
I don't know which stamp you are using, but most likely you are seeing
exactly what the BS2's PWM command produces. It is supposed to work
differently from conventional PWM. A rapid sequence of short pulses, some as
short as 4uS are generated that will equal the desired PWM proportion every
millisecond. It can get you to the output level quickly, but won't ever give
you nice, ordered pulses, as you are expecting.
Chris
> From: Tim Stockman, STOCKMAN ELECTRONICS [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VCbCIsW6PtY1c8dh0_xXSQrCsSfiJJdBsInISPby8mVucsydCTZH-8ag3ePl5I0BvJT_OSZpny9i_Ksktw]stocky@c...[/url
> Sent: Thursday, October 18, 2001 7:08 AM
> Subject: [noparse][[/noparse]basicstamps] Fw: BS1 PWM
> This message didn't seem to make it to the list last time.....
> seems to vary, as in the steps dont seem to be the same, eg
> for exampel if a step is supposed to be 0.0196v the steps
> Subject: BS1 PWM
> Stampers,
> How accurate is it?
> steps do PWM seems to fit the bill perfectly. We will monitor
> that volatge with an input that has a 100k input impedance.
> Stocky
> from the same email address that you subscribed. Text in the
Are you using an RC/op-amp filtering circuit with the PWM? (BS1
ap-note 15) That is very necessary in order to get even steps. I
don't know what you mean when you say, "We will monitor that volatge
with an input that has a 100k input impedance. That should not apply
to much of a load I would hope!" Yes, too much load if there is not
an op-amp buffer.
See also,
http://www.emesystems.com/BS2PWM.htm
-- regards,
Tracy Allen
mailto:tracy@e...
>vary, as in the steps dont seem to be the same, eg for exampel if a
>step is supposed to be 0.0196v the steps don't follow the pattern
>Subject: BS1 PWM
>Stampers,
> How accurate is it?
>PWM seems to fit the bill perfectly. We will monitor that volatge
>Stocky
