The quest for clean code... — Parallax Forums
edited 2001-10-16 20:27 in General Discussion
The goal of this section is to read the highest pin that is high, and
report the corresponding number. Is there a
better/smaller/faster/cleaner way to do this? I do not like jumping to a
line just to set a variable.
-paul
ReadFret:gosub ioset:
b0 = in15:if b0 then fret11
b0 = in14:if b0 then fret10
b0 = in13:if b0 then fret9
b0 = in12:if b0 then fret8
b0 = in11:if b0 then fret7
b0 = in10:if b0 then fret6
b0 = in9:if b0 then fret5
b0 = in8:if b0 then fret4
b0 = in7:if b0 then fret3
b0 = in6:if b0 then fret2
b0 = in5:if b0 then fret1
b0 = in4:if b0 then fret0
b1=1: return
fret0: b1=50:return
fret1: b1=2:return
fret2: b1=3:return
fret3: b1=4:return
fret4: b1=5:return
fret5: b1=6:return
fret6: b1=7:return
fret7: b1=8:return
fret8: b1=9:return
fret9: b1=10:return
fret10:b1=11:return
fret11:b1=12:return
    edited 2001-10-16 15:25
    How about:
    b0=ncd ins
    if b0=0 then no_high
    b0=b0-5 ' gives 0-11
    Al Williams
    AWC
    * Floating point A/D
    http://www.al-williams.com/awce/pak9.htm
    From: Paul Jordan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ueOPlokSS0hL_yFPo4z8qz7LxfuVcgT62XupXiwGSy_Co2hnddm151lMO0834cgqPIBLPsPvBx3i1ym8HZjarj5zvwC-]automations@c...[/url
    Sent: Tuesday, October 16, 2001 9:09 AM
    Subject: [noparse][[/noparse]basicstamps] The quest for clean code...
    -paul
    b1=1: return
    fret0: b1=50:return
    fret1: b1=2:return
    fret2: b1=3:return
    fret3: b1=4:return
    fret4: b1=5:return
    fret5: b1=6:return
    fret6: b1=7:return
    fret7: b1=8:return
    fret8: b1=9:return
    fret9: b1=10:return
    fret10:b1=11:return
    fret11:b1=12:return
    edited 2001-10-16 15:29
    Yes, there is an easier way: The NCD fuction,combined with LOOKUP. NCD will
    return a value (0 - 16) indicating the highest bit set in the variable used
    with it. If zero, no bits were set. If 16, then Bit15 was set. LOOKUP
    provides a neat way to enter a simple table (Note: the first element is
    indexed at zero).
    For your code, you could do this:
    theBit VAR Byte
    bitVal VAR Byte
    theBit = NCD Ins
    LOOKUP theBit,[noparse][[/noparse]1,1,1,1,1,50,2,3,4,5,6,7,8,9,10,11,12],bitVal
    Notice how easy your code becomes when you take advantage of PBASIC's
    functions. You could replace the LOOKUP line with multiple IF...THEN's, but
    the code wouldn't be as clean or easy to modify.
    STRONG SUGGESTION: DO NOT USE internal variable names like B0 and B1. Use
    names that will give your code some meaning and use only the amount of space
    you need. This will let the compiler organize the variable space and will
    elimnate possible conflicts.
    -- Jon Williams
    PS: Programming Note: You cannot RETURN from a GOTO which is implicit in
    PBASIC's IF...THEN.
    In a message dated 10/16/01 9:13:00 AM Central Daylight Time,
    automations@c... writes:
    > Thanks
    > -paul
    > b1=1: return
    > fret0: b1=50:return
    > fret1: b1=2:return
    > fret2: b1=3:return
    > fret3: b1=4:return
    > fret4: b1=5:return
    > fret5: b1=6:return
    > fret6: b1=7:return
    > fret7: b1=8:return
    > fret8: b1=9:return
    > fret9: b1=10:return
    > fret10:b1=11:return
    edited 2001-10-16 15:42
    Check out the LOOKUP command. It allows you to assign a value to a variable
    based on an index.
    > Thanks
    > -paul
    > b1=1: return
    > fret0: b1=50:return
    > fret1: b1=2:return
    > fret2: b1=3:return
    > fret3: b1=4:return
    > fret4: b1=5:return
    > fret5: b1=6:return
    > fret6: b1=7:return
    > fret7: b1=8:return
    > fret8: b1=9:return
    > fret9: b1=10:return
    > fret10:b1=11:return
    > fret11:b1=12:return
    edited 2001-10-16 15:54
    Whoops didn't look far enough down to see the other values. As other
    suggested, the LOOKUP command will get you the rest of the way.
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller
    http://www.al-williams.com/awce/pak1.htm
    From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ylibVH38heIpSemZm-GHlNtM_KIgzNqSfrJgvyLNv8b0h3ysQaeQz1dsOgru59XGES3O8nm24726cloOIQ]alw@a...[/url
    Sent: Tuesday, October 16, 2001 9:25 AM
    Subject: RE: [noparse][[/noparse]basicstamps] The quest for clean code...
    How about:
    b0=ncd ins
    Al Williams
    AWC
    From: Paul Jordan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NIBEv609xEuhxxJ3S8yrgFM-ftsxrUPumChizXCsS7h0tMTQvIOMqc3wNoX4XMvuCHc8i8Q_uUW1WEDilPdfovTvqeum]automations@c...[/url
    -paul
    b1=1: return
    fret0: b1=50:return
    fret1: b1=2:return
    fret2: b1=3:return
    fret3: b1=4:return
    fret4: b1=5:return
    fret5: b1=6:return
    fret6: b1=7:return
    fret7: b1=8:return
    fret8: b1=9:return
    fret9: b1=10:return
    fret10:b1=11:return
    fret11:b1=12:return
    edited 2001-10-16 20:11
    We can save 8 more bytes in program memory by using an
    algorithm specific to the result. By clamping a
    Minimum at 1, we can address the cases where any input
    above in4 is high together with the cases where no
    input between in4 and in15 is high. The special case
    of in4 being the highest true input does not present
    an elegant algebraic solution, so we skip around.
    theBit VAR Byte
    bitVal VAR Byte
    theBit = NCD Ins
    bitVal = 50 ' handle special case for in4
    if theBit = 5 then skp ' retain value for special case
    bitVal = (theBit - 4) Min 1 ' handle all other cases
    skp:
    Bob Pence
    > indexed at zero).
    > theBit VAR Byte
    > bitVal VAR Byte
    > theBit = NCD Ins
    > LOOKUP
    > -- Jon Williams
    > PBASIC's IF...THEN.
    > Daylight Time,
    > > Thanks
    > > -paul
    > > b1=1: return
    > > fret0: b1=50:return
    > > fret1: b1=2:return
    > > fret2: b1=3:return
    > > fret3: b1=4:return
    > > fret4: b1=5:return
    > > fret5: b1=6:return
    > > fret6: b1=7:return
    > > fret7: b1=8:return
    > > fret8: b1=9:return
    > > fret9: b1=10:return
    > > fret10:b1=11:return
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    Bob Pence
    NOTE: This mail is sent using my wireless phone. Calling me at 1 (610) 563-6198
    is preferred to a reply. If replying to this email address, please do not quote
    the original message.
    __________________________________________________
    Do You Yahoo!?
    Make a great connection at Yahoo! Personals.
    http://personals.yahoo.com
    Yep ... that works too and demonstrates the flexibility of PBASIC. I have a
    tendancy to err on the side of easy, verbose code -- but there are as many
    ways to write a program as there are to skin a cat (no offence to feline
    lovers).
    -- Jon Williams
    In a message dated 10/16/01 2:13:24 PM Central Daylight Time,
    bobpence_2000@y... writes:
    > theBit VAR Byte
    > bitVal VAR Byte
    > theBit = NCD Ins
