DS 1302 12/HR Mode
I am looking for documentation or sample code for using the 12/hr
mode of the DS1302 clock chip. Or is it simpler to convert to 12 hr
mode using math and the // operator?
bit. When high, the 12-hour mode is selected. In the 12-hour mode, bit 5
is the AM/PM bit with logic high being PM. In the 24-hour mode, bit 5 is
the second 10-hour bit (20-23 hours).
Right from the manual.
James R. Parish
J-Tech Internet Services
J-Com Enterprises, Inc.
From: coondog45@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7kygsqqiru2NGI-JMZIcjcIwU4IAKACl57X9HlnP4m-J8reXeY4C4YSZ692d8hS5vnjzlmTC901erZXo]coondog45@h...[/url
Sent: Tuesday, October 16, 2001 4:41 AM
Subject: [noparse][[/noparse]basicstamps] DS 1302 12/HR Mode
you write to register to set the time? Also I guess you have to set
bit 5 also to tell the chip it is AM or PM, do you do this when
setting bit 7 high?
--- In basicstamps@y..., "James R. Parish" <wiz@a...> wrote:
> Bit 7 of the HOURS REGISTER is defined as the 12- or 24-hour mode
select
mode, bit 5
bit 5 is
> James R. Parish
> From: coondog45@h... [noparse][[/noparse]mailto:coondog45@h...]
> To: basicstamps@y...
> basicstamps-unsubscribe@y...
Subject and
