Sensing hand presence — Parallax Forums
edited 2001-10-16 12:02 in General Discussion
I am working on a project where a sensor senses the present of a
hand when gets withing 1/2" of its surface and have that signal
detected by a stamp. I know that there are some capacitive solution
to that but not sure how. Any ideas?
Al Najjar
    edited 2001-10-16 08:23
    >Al Najjar
    Try http://www.qprox.com/. I have their e11x demo board which I think
    was around $15 and does exactly that, sends out +5v if you get within
    about .5 inches of the sensing area. You can extend the sensing area
    by attaching a wire to the board and running it wherever you want the
    sensor to be active. Relatively cheap and easy to use. And If I can
    get something to work, then believe me, it's easy to use... [noparse];)[/noparse]
    If you want the IC without the fancy board it should be under $2
    each. Here's a link to the IC I think you could use >
    http://www.qprox.com/products/qt11x.php3
    Mark
    An alternate solution would be an infrared emitter/detector pair
    available at Radio Shack. There was an article in last year's
    October issue of Nuts & Volts demonstrating this.
    Carl
