PULSOUT maths
Archiver
This works for me. Try this code with your servo.
'Servo signal on pin0
'Fully CW = 180
'Fully CCW = 1170
'Variables & Constants
Counter Var Byte
Position Var Word
ToServo Con 0
'*********************Main Program
Start:
For Position = 180 To 1170 Step 20
Pulsout ToServo, Position
Pause 15
Next
For Position = 1170 To 180 Step 20
Pause 15
Next
Goto Start
From: Justin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TkTPFnWuK0aWtAWo7_wmKPlCOLazo2iUZIVyx_PbRg-gBCnae1fAiHvfqJpkjvoohviBbv8de8JOSUVJjw]justin@j...[/url
Sent: Monday, October 15, 2001 9:35 AM
To: Basicstamps (E-mail)
Subject: [noparse][[/noparse]basicstamps] PULSOUT maths
Hi all.
Can someone please check my reasoning here ? I want to generate a 1.5ms
pulse from a BS2-SX to control a servo.
The stamp manual (v2.0) states that the BS2-SX handles Period values in
0.8us increments.
Given that 1us = 1/1000000 = 0.000001s
and 0.8us = 0.000001 / 10 * 8 = 0.0000008s
Ok, I think this means that to generate a 1.5ms pulse (1.5ms = 0.0015s), I
need to use the following sum;
0.0015 / 0.0000008 = 1875
But, when I run my program, the servo receiving the pulse won't stand still
I have tested and calibrated the servo with a BS-1 which outputs a 1.5ms
pulse and all is ok - it stops nicely and goes forward or backwards when the
pulse moves either side of 1.5ms.
I've tried values from 1250 ( 1ms) to 2500 (2ms) but with no luck.
I know this is a very basic question but I've spent too many late nights
trying to figure it out ! Can anyone tell me what stupid mistake I've made
Thanks in advance,
Justin.
'Fully CW = 180
'Fully CCW = 1170
Counter Var Byte
Position Var Word
ToServo Con 0
Start:
Pause 15
Next
Pause 15
Next
Goto Start
Hi all.
0.8us increments.
Thanks in advance,
Justin.
0.8us increments.
Thanks in advance,
Justin.
You *should* run your servos off a separate battery from the Stamp. Be sure
the grounds for the servo and Stamp batteries are tied together. If you
can't run two batteries, you need to make sure the battery you are using can
supply enough power to run both the servo and Stamp, and you must provide
some filtering to prevent the servo motor noise from making the Stamp reset.
When the stamp resets the servo may chatter or move slightly.
The values for calculating the PULSOUT units are an average. Because the
clock frequency on the Stamp will vary slightly, these figures will also
vary. On my BS2SX robot 1550 is the PULSOUT value to move the servo to the
center of the travel. If you have too high or low a value, the servo will
turn all the way one way or the other, bang against the stops and chatter
away.
> 0.8us increments.
still
the
made
code on a BS2-SX ?
From: Dennie Bishop [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=C5c61XrDkdtLDGZ9s1XyVyL6mQTnPpnOLfShebRePyFtvziW13zefcf-1v6MnAWKpJPCuhI9Zqd1eygpURq3Nbww0vsXzy4wwwiO]dbishop@e...[/url
Sent: 15 October 2001 14:28
Subject: RE: [noparse][[/noparse]basicstamps] PULSOUT maths
'Fully CW = 180
'Fully CCW = 1170
Counter Var Byte
Position Var Word
ToServo Con 0
Start:
Pause 15
Next
Pause 15
Next
Goto Start
From: Justin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-G32xZZ2bEuchcApSx6uammAB99Y050DyOhSH-QdgS97owkD-MngQvlxTdiw2_2y8mB2fivnF99H-Z8vxWkRwZbJ]justin@j...[/url
Hi all.
0.8us increments.
Thanks in advance,
Justin.
I can't believe I forgot to tie the grounds together.
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BMmDTOKqTE2ylVdAMFX-La0_GZ5nTwswsg-jsx2RWxKSq9lTos6p3YVxwbPy4F6_NReGHnPfzK7x]daweasel@s...[/url
Sent: 15 October 2001 14:37
Subject: Re: [noparse][[/noparse]basicstamps] PULSOUT maths
Two things to consider:
away.
> 0.8us increments.
still
the
made
> Doh !
sure
can
reset.
> away.
> > 0.8us increments.
I
> still
> the
> made
I have to double-triple-check alot my work because my brain takes a holiday
periodically. I can remember the right way to do something, but my hands go
off on their own and do the wrong things.
> Yeah - but this isn't my first servo !!
> BTDT. Spend a week trying to get my first servo working.
> > Doh !
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cbs5ZxuJHHAf9dnGpI5p92cIUZjJFb9ZyY16w2yVsYPRTsAPKs6suyi0eU1BnlAgUF-oJdGA4ul0]daweasel@s...[/url
Sent: 15 October 2001 15:26
> Doh !
sure
can
reset.
> away.
> > 0.8us increments.
I
> still
> the
> made
move the stamp.
Like this:
vector var word
vector = 2000
servo:
pulsout pin,vector
pause 20
goto servo
Change the vector variable to move the servo. If there is sufficient
delay in your program between the servo pulses, you may or ,ay
not need the pause line.
Doug
This will move the servo to the 2000 location and hold it there.
On 15 Oct 2001, at 14:35, Justin wrote:
> Hi all.
> 1.5ms pulse from a BS2-SX to control a servo.
> in 0.8us increments.
> 0.0015s), I need to use the following sum;
> still !
> 1.5ms pulse and all is ok - it stops nicely and goes forward or
> backwards when the pulse moves either side of 1.5ms.
> nights trying to figure it out ! Can anyone tell me what stupid
> mistake I've made ?
> Thanks in advance,
> Justin.
> and Body of the message will be ignored.
for the CPU and the servos and I hadn't tied the grounds together. At least
I know my maths were right !!
Justin.
From: veewee77@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=srtVS7hAMGeu0R8ghyAPiGotTc96124fLEFJZim3nvmhM8iFRhnrEAtLYzU8YIWLOQYvM60Yz5G-lLaC1w]veewee77@a...[/url
Sent: 15 October 2001 23:31
Make sure you have the pause or delay between the pulses to
move the stamp.
Like this:
vector var word
vector = 2000
servo:
pulsout pin,vector
pause 20
goto servo
Doug
> Hi all.
> still !
> mistake I've made ?
> Thanks in advance,
> Justin.
