Laser guided BOE bot project
As part of a school project, I'm attempting to build a laser guided
pinewood derby car using a BOE bot full kit.
The designator is a normal laser pointer that projects a plane
instead of a beam, and the car is designed such that the two photo
resistors in the kit ride on either side of the beam.
when the beam hits one of the photoresistors, I need the car to steer
away from the resistor, so the beam moves back between the two
sensors.
so far, my program looks like this:
'declaration
left_photo var word
right_photo var word
'init
output 2
freqout 2, 2000, 3000
low 12
low 13
'main
main:
high 3
pause 3
rctime 3,1, right_photo
high 5
pause 3
rctime 5,1,left_photo
pulsout 12, 750 'center servo
pause 100
if abs(left_photo-right_photo) >50 then check_dir 'set dead band
goto main:
check_dir:
if left_photo > right_photo then right_pulse
if left_photo < right_photo then left_pulse
'nav
left_pulse:
pulsout 12, 625
pause 100
gosub update_photo
if left_photo > right_photo then right2
goto main
right_pulse:
pulsout 12, 825
pause 100
gosub update_photo
if left_photo < right_photo then left2
goto main
left2:
pulsout 12,825
pause 200
goto main
right2:
pulsout 12,625
pause 200
goto main
'----subs
update_photo:
high 3
pause 3
high 5
pause 3
return
It doesn't work all that reliably, and it has a tendency to make the
servo lock in either the far right or far left position.
Am i conplately screwing up somewhere?
thanks for the help.
sensors.
'declaration
left_photo var word
'init
output 2
low 12
low 13
'main
main:
high 3
pause 3
high 5
pause 3
pause 100
goto main:
check_dir:
'nav
left_pulse:
pulsout 12, 625
pause 100
gosub update_photo
goto main
right_pulse:
pulsout 12, 825
pause 100
gosub update_photo
goto main
left2:
pulsout 12,825
pause 200
goto main
right2:
pulsout 12,625
pause 200
goto main
'----subs
update_photo:
high 3
pause 3
high 5
pause 3
return
respond well enough with pulsouts spaced at least 100 milliseconds apart.
try a small for next loop with your pulsouts and put a 20 MS pause in the
loop. I modified your code a bit. See if it is closer to what you want.
From: drew_123456@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kHMXEBoV-UjGH2sKPjt9TBpA3rBHZmgAMASQktZpN6K57UHn9n6RfDpdzvKSB_C3lCpG__HPO3MnYytFRQ]drew_123456@y...[/url
Sent: Thursday, October 11, 2001 11:23 PM
Subject: [noparse][[/noparse]basicstamps] Laser guided BOE bot project
sensors.
'declaration
left_photo var word
i var byte
'init
output 2
low 12
low 13
'main
main:
high 3
high 5
pause 3
rctime 3,1, right_photo3
if abs(left_photo-right_photo) >50 then center_pulse 'set dead band
goto main
'nav
left_pulse:
for i = 1 to 5
pulsout 12, 625
pause 20
next
goto main
right_pulse:
for i = 1 to 5
pulsout 12, 825
pause 20
next
goto main
center_pulse:
for i = 1 to 5
pause 20
next
goto main
the servo. (Of course this will not work if the servo wanders when it is not
receiving commands.) Play with the for next loops to fine tune. Use just
enough loops to get the steering servo to the correct position.
'declaration
left_photo var word
i var byte
state var nib
'init
output 2
low 12
low 13
'main
main:
high 3
high 5
pause 3
if abs(left_photo-right_photo) >50 and state <>3 then center_pulse 'set dead
band
if left_photo > right_photo and state <>2 then right_pulse
if left_photo < right_photo and state <>1 then left_pulse
goto main
'nav
left_pulse:
for i = 1 to 5
pulsout 12, 625
pause 20
next
state = 1
goto main
right_pulse:
for i = 1 to 5
pulsout 12, 825
pause 20
next
state = 2
goto main
center_pulse:
for i = 1 to 5
pause 20
next
state = 3
goto main
Your concept is interesting, but I see a little problem with it: each
steering correction results in sideways slippage of the wheels and increased
friction, which will result in the car's velocity being decreased (exactly
the opposite effect of what you desire). Determining the exact amount of
steerage to apply is problematic; and you have no way to determine as to
when the car's steerage is centered.
Consider this improvement:
Salvage a small stepper motor from an old 3 1/2" floppy disk drive. (see
the Basic Stamp I Application Notes, 6:A Serial Stepper Controller). To the
shaft of the stepper motor, affix a small circular PCB (maybe 1" in
diameter) on which you've mounted a photoresistor (I'll call this PR1 for
now) off-center, and cut a radial slot or drilled a small hole opposite the
photoresistor. Shine a stationary LED through the slot or hole, and mount a
stationary photoresistor (PR2) on the opposite side of the PCB disk to
detect the LED through the hole. On the motor side of the PCB, etch or cut
two circular traces, and fabricate pickups from narrow strips of brass to
supply sensing lines to PR1.
The laser designator's beam is projected with the plane in the Y axis
(vertical), exactly centered on the track. The number of steps per
revolution of the motor is fixed. PR2 provides a method of determining when
the disk is in a known position; a synchronization pulse to your Stamp
program, so to speak. As PR1 travels through it's circular path, your Stamp
program samples the amount of light detected at each step; if the light is
strongest when PR1 is at the highest or lowest portion of it's travel (on an
imaginary vertical line intersecting the center of the motor's shaft), then
the car's steering should be exactly centered; otherwise your program could
determine how much and which direction the wheels should be adjusted.
Using this method provides you with a way of determining the exact amount of
steerage to be applied to the car's wheels, and will minimize speed losses
due to friction.
Hope this helps... on to victory!
Steve
