BS2 newby questions
Hi guys,
First off I know little more about the BS2 than is available on the
parallax website.
I think I need to use a stamp and it will probably be the BS2 as I
need to access it via the serial port.
1.
Can the BS2 be powered by the serial port of a PC?
2.
Once programmed is it possible to burn a link/fuse (whatever) to stop
the program and data from being modified? The app I have in mind will
be associated with a PIC programmer so I do not want the headache of
someone modifying the BS2 code and then hollering for tech support
because they screwed it up.
Thanks in advance.
parallax website.
1.
2.
Thanks in advance.
