Pressure Sensors
Try Newark Electronics - they have many pressure sensors both by
Motorola and Honeywell, in many configurations, depending on what pressure
measurement you need to take. I have used the Honeywell sensors for data
acquisition and was impressed.
Tim
Timothy Medema
CrystaLite, Inc.
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Tim
Timothy Medema
CrystaLite, Inc.
computer.
My wife buys your company's product in the LARGE package, and I always gag
when I see the price!
But really - thanks. I have been through most of the catalog houses,
including Newark. The best way to describe the problem I'm having with this
is to say that I prefer to use component level technology for both the cost
and control benefits. Perhaps I should have said that I'm looking for a
sensing component instead of a sensor. It seems that the catalog people sell
what are more appropriately described as transducers. Silicon-Piezo types
are certainly sensors that are affordable, but they output only during
pressure changes. The effort needed to convert the output into a gauge type
function would be intense. The micromachined silicon that Honeywell uses in
their 'sensors' is in the form of a chip that sells as a $2 or $3 component.
This is the type of cost that's needed for my product development. If
someone needed to build one sensor into a control project to be used in
another industrial process, the $200 Honeywell would be fine.
BTW, how did that last stamp project work out for you?
Chris
> From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mdSbsEO2D4NAJCpuzRHWDxTgFF4AfhSE3QMMZbmNS-feEBQgobDBD-N7YvCLAGUHPoPrcGDLOEbrduhk]timm@c...[/url
> Sent: Tuesday, October 09, 2001 2:28 PM
> Subject: [noparse][[/noparse]basicstamps] Pressure Sensors
> sensors both by
> what pressure
> sensors for data
> Tim
> Timothy Medema
> CrystaLite, Inc.
> or entity to
> use of, or
> you received
> material from any
> computer.
> from the same email address that you subscribed. Text in the
Sorry to disappoint you, but my company doesn't make the drink mix
- that's also the reason you haven't seen the lemonade yet either.
I should have figured that you had checked with Newark already -
my apologies for misunderstanding that you were looking for the sensing
component itself. The Honeywell sensor that I had used did come in the
gauge type configuration, and I believe that they cost about 26 or 27
dollars at that time (2 years ago). Sounds like that is still way out of
your budget though.
In regards to your question about my last Stamp project, so many
projects have come and gone since then that in all honesty I don't remember
which one the "last" one was!
Tim
At 04:24 PM 10/9/2001 -0400, you wrote:
>Hey Tim, What ever happened to all that Lemonade you were supposed to send?
>Chris
> > From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CQDij-ZOPj5crqeYvFhwf1Ip7Z6n2zWqw6_b55KUm4pDtkM88iYE_5Bw5cg65RfWk_kT_9pRGVgvIAA37jc]timm@c...[/url
> > sensors both by
> > what pressure
> > sensors for data
> > Tim
> > Timothy Medema
> > CrystaLite, Inc.
> > or entity to
> > use of, or
> > you received
> > material from any
> > computer.
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
