Yet another servo question
Would the BS2P24 (or for that matter the mormal BS2) be capable in speed to sit
between a normal RC car receiver and servo and act as a fail safe for when my
batteries for the receiver go dead? I would need less than 20ms lag between
input and output, and a reaction time inside of 20ms as well.
In addition, I need to to collect data from all 4 wheels and 2 points on the
drive shaft and control 3 seperate brakes to start on an ABS type system for my
RC rally car (its gas powered). I'll need to send a few samples every few
seconds via wireless, control an electric gas valve.
Would a stamp be up to this task or am I looking into the wrong MCU for this
application? If I am looking into the wrong MCU, any suggestions as to what I
should use? Basic requirements are low power, low weight, and small footprint,
but it isn't a deal breaker if low power or low weight can't be met, but small
footprint is a solid requirment. There is already a small wireless camera and a
few other sensors for feul level and head temp so I've got limited space
remaining. The ground speed is around 45mph and the entire car is subjected to
severe vibration (engine tops out at near 30,000 rpm) so ruggedness could play a
part in the final choice.
Thanks for your time,
Rob
Rob
i hope this helps.
I am currently in the early stages of designing a autopilot for my R/C
helicopter. It needs to read in 3 inputs from the receiver then 2 inputs
from an external chip then mix these signals and output them to the 3
servos.
What i am finding is that even just reading the receiver then outputing to
the servos seems to slow the response time of the servos by a noticable
amount. I have not investergated this as yet but i think it is because i
might need to change the order the servos are sampled in.
I started using a BS2 but have now moved to a BS2sx ( i needed the ram and
the bs2p was to expensive at the time.)
I am thinking about using one of the serial servo chips that are on the
market to do the servo updates then this would take the load off the BS2 to
allow it to do the mixing as needed.
In short yes the BS2 range can read and then output but how quickly it
responds might be your problem. but if you allready own a BS2 then give it a
shot. what have you got to loose.
If you would like any more info from what i have, let me know and i will
send it to you.
Regards
Peter Rogers
Sent: Tuesday, October 09, 2001 3:00 PM
Subject: [noparse][[/noparse]basicstamps] Yet another servo question
to sit between a normal RC car receiver and servo and act as a fail safe for
when my batteries for the receiver go dead? I would need less than 20ms lag
between input and output, and a reaction time inside of 20ms as well.
the drive shaft and control 3 seperate brakes to start on an ABS type system
for my RC rally car (its gas powered). I'll need to send a few samples
every few seconds via wireless, control an electric gas valve.
this application? If I am looking into the wrong MCU, any suggestions as to
what I should use? Basic requirements are low power, low weight, and small
footprint, but it isn't a deal breaker if low power or low weight can't be
met, but small footprint is a solid requirment. There is already a small
wireless camera and a few other sensors for feul level and head temp so I've
got limited space remaining. The ground speed is around 45mph and the
entire car is subjected to severe vibration (engine tops out at near 30,000
rpm) so ruggedness could play a part in the final choice.
> Rob
out [noparse];)[/noparse]
If I could ask you to send me a snippet of the code you're using to read the
servos, that would help more than anything. I was thinking the same thing
with using the serial servo chips that are available to off-load some of the
work.
Lag in the throttle response can be overcome with a little human retraining,
but there can't be any more than the 20ms lag in braking, things on the
courses happen too fast. I think it would be possible to do the intercepting
with the stamp, but the stamp would also have to be counting 6 encoder
wheels (1 on the front drive shaft, 1 on the rear drive shaft, and 1 on each
wheel). I guess I could drop to just have the front wheels being anti-lock
reducing my sample load by 50%. I could even use a second controller to
detect a wheel lock situation, and just bring an alarm pin high on the stamp
with the servos.
Once we have the basics of doing the ABS system completed, our ultimate goal
is an "all wheel drive" system with 4 independant brakes at each wheel and
maybe a slightly more real-time configurable center differential. With
things being as close as they are even over a 2 hour race (1st and 8th place
are normally seperated by less than a minute), an advantage in the turns
like all wheel drive and ABS could make things interesting. At least for my
team [noparse]:)[/noparse]
Robert Staph, W3RCS
Sent: Tuesday, October 09, 2001 8:12 AM
Subject: Re: [noparse][[/noparse]basicstamps] Yet another servo question
> Robert,
> i hope this helps.
> servos.
to
a
> send it to you.
> Regards
> Peter Rogers
> From: "Robert Staph" <rstaph@a...>
for
lag
system
to
small
I've
30,000
> > Rob
and
Helicopters are fun. and your right you probably will crash. if its not your
first flight then your second or third etc. But thats part of the fun. and
if you take it slowly you can say well i know what i did wrong there so i
wont do that again. Also with helicopters its possible to learn to fly by
yourself ( unlike planes.) as the first thing you learn is to take off,
hover and land. then you learn to fly.
to check out my code etc look at my web page.
http://members.optushome.com.au/progers/
i think all the info is there but the layout is not very good. but hey im
not a web page designer. :-)
Also the problem im having does not seem to be a delay its more like the
servo is moving at a slower speed.
Also if i remember right on most RC cars with 4wd are direct drive systems
either by belt or something right. So where do the brakes come into it? or
am i thinking about the wrong type of RC
Let me know how you go.
Also if i can answer any questions or if you can answer some of mine :-)
please let me know
Regards
Peter Rogers
Sent: Tuesday, October 09, 2001 11:47 PM
> I almost got into RC heli's, but I know I'd crash and burn the first
flight
the
the
> work.
retraining,
intercepting
each
anti-lock
stamp
> with the servos.
goal
place
my
> Robert Staph, W3RCS
> From: "Peter Rogers" <molly7@o...>
> > Robert,
> > i hope this helps.
> > servos.
to
and
> to
it
> a
> > send it to you.
> > Regards
> > Peter Rogers
speed
> for
> lag
on
> system
for
as
> to
> small
be
small
> I've
> 30,000
> > > Rob
> and
and
This sounds like an interesting project!
Doug
> speed to sit between a normal RC car receiver and servo and act as a
> fail safe for when my batteries for the receiver go dead? I would
> need less than 20ms lag between input and output, and a reaction time
> on the drive shaft and control 3 seperate brakes to start on an ABS
> type system for my RC rally car (its gas powered). I'll need to send
> a few samples every few seconds via wireless, control an electric gas
> valve.
> for this application? If I am looking into the wrong MCU, any
> suggestions as to what I should use? Basic requirements are low
> power, low weight, and small footprint, but it isn't a deal breaker if
> low power or low weight can't be met, but small footprint is a solid
> requirment. There is already a small wireless camera and a few other
> subjected to severe vibration (engine tops out at near 30,000 rpm) so
> Rob
> and Body of the message will be ignored.
voltage) to the radio and have the stamp replace the servo's input
with the stop position? You don't have to do any conversion. Use
a bilateral switch between the radio receiver and the servo, and one
between the stamp and the servo. Us the stamp's output to
operate the switches and switch in either the signal from the radio
(normal operation) or the appropriate signal to stop (error
condition). This way there is no lag at all and you don't hav eto
monitor anything but voltage to the radio. You could also add a
loss-of-carrier error measurement incase the radio control unit quits
for whatever reason. This would shut down the car in the event you
tripped, or the battery dies in your controller, etc.
On 10 Oct 2001, at 21:58, Peter Rogers wrote:
> Robert,
> not your first flight then your second or third etc. But thats part of
> the fun. and if you take it slowly you can say well i know what i did
> wrong there so i wont do that again. Also with helicopters its
> possible to learn to fly by yourself ( unlike planes.) as the first
> thing you learn is to take off, hover and land. then you learn to fly.
> hey im
> the servo is moving at a slower speed.
> systems either by belt or something right. So where do the brakes come
> into it? or am i thinking about the wrong type of RC
> :-) please let me know
> Regards
> Peter Rogers
> flight
> > read
> the
> > thing with using the serial servo chips that are available to
> > off-load some of
> the
> > work.
> retraining,
> > the courses happen too fast. I think it would be possible to do the
> intercepting
> > encoder wheels (1 on the front drive shaft, 1 on the rear drive
> > shaft, and 1 on
> each
> anti-lock
> > controller to detect a wheel lock situation, and just bring an alarm
> > pin high on the
> stamp
> > with the servos.
> > ultimate
> goal
> > wheel and maybe a slightly more real-time configurable center
> > differential. With things being as close as they are even over a 2
> place
> > turns like all wheel drive and ABS could make things interesting.
> > At least for
> my
> > Robert Staph, W3RCS
> > > Robert,
> > > i hope this helps.
> > > R/C helicopter. It needs to read in 3 inputs from the receiver
> > > then 2 inputs from an external chip then mix these signals and
> > > output them to the 3 servos. What i am finding is that even just
> to
> > > noticable amount. I have not investergated this as yet but i think
> > > it is because i might need to change the order the servos are
> > > sampled in. I started using a BS2 but have now moved to a BS2sx (
> > > i needed the ram
> and
> > > on the market to do the servo updates then this would take the
> > > load off the BS2
> > to
> > > quickly it responds might be your problem. but if you allready own
> > > a BS2 then give
> it
> > a
> > > i will send it to you.
> > > Regards
> > > Peter Rogers
> > > > in
> speed
> > > fail safe
> > for
> > > than 20ms
> > lag
> > > well.
> > > > points
> on
> > > type
> > system
> > > valve.
> > > > MCU
> for
> > > suggestions
> as
> > to
> > > and
> > small
> > > can't
> be
> > > a
> small
> > > temp so
> > I've
> > > the entire car is subjected to severe vibration (engine tops out
> > > at near
> > 30,000
> > > > Rob
> > > > Subject
> > and
> > > Subject
> and
> > Subject and
The car is modified from the stock pieces to have limited slip front and rear
differentials, as well as an adjustable-slip center differential. Its all shaft
driven, and behaves very much like a real rally car. On a shorter track you
spend more time braking than anything thing else. On loose dirt and small
gravel tap the brake a little to hard and your in for a 180. We don't get to
have a reverse gear, so staying straight and forward is the most important thing
to do. The brakes come into play either on the outdrives from the center diff
or, once we have them all machined out, 4 disc brakes at the wheels.
-Rob
