Basic Stamps and Music
Hello all,
I do not have any of the basic stamps or have ever used one.
I am considering using one to simulate a wind instrument.
With the basic stamp as a stand alone device could I create
data for each note and play each note simultaniously depending
on what buttons are pressed to convincingly create a flute?
I know there is an add on device for speech recognition and
for playing .wav files put I want to avoid extra devices for
now.
I know I may need to build an audio mixer to output to a single
speaker or headphone.
Would this be a practical application and are there some
recommended tools to help with this project?
Alan
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
now.
Alan
The Basic Stamp is not going to produce more than one note at a time. You
can have it output two frequencies at the same time, but its not truly
polyphonic.
> now.
alan_fullarton@h... writes:
Probably not. The BASIC Stamp can generate tones, but not in the manner that
the device you suggest requires. You could pre-program a simple tune, but
the output would require serious filtering to approximate the sound of a
flute.
-- Jon Williams
Another thought ... you probably could use the Stamp as a custom interface
for a midi controller. Of course, you'd require a midi instrument to play
the notes.
-- Jon Williams
The art installation I did for burning man this year was a stamp-based
project which took class IIIa laser emitters / detectors and generated
midi data which got interpreted by a synth and amplified. Works good. IF
you want to see a board design or a CAD drawing I can supply it ; oddly
enough, I have gerber files, but no schematic. Basically, the board uses a
BS2 to have 15 input lines from switches (in this case photoresistors) and
the final line as an I/O line for the midi data. It's a pretty simple
circuit ; the programming was much more complicated. But I'm a programmer
by history, so it worked out well that way.
Check out http://www.zenchemical.com/burningman/congruence for a very
brief project description and some pictures, and let me know if you have
any questions about stamp/midi interfacing. I also have some extra boards
which I might let go ; the fabrication cost me $150 for 8 of them.
On Thu, 4 Oct 2001 jonwms@a... wrote:
> In a message dated 10/4/01 7:30:12 PM Central Daylight Time,
> the notes.
> -- Jon Williams
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
I will think about this method, it sounds good.
Thanks all for your help an ideas.
Alan
>From: "Sean T. Lamont .lost." <lamont@a...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] Basic Stamps and Music
>Date: Thu, 4 Oct 2001 18:03:29 -0700 (PDT)
>Oddly enough, I've done exactly that.
