Parallax-BS2P Plus Pack is now available!
The NEW BS2P Plus Pack allows you to optimize the advanced capabilities of
the BS2P module. With the included parts, our code and documentation, you
will be interfacing to I2C, 1-wire, and parallel LCD's in no time. We
recommend using our default source code to get started and customize
the code accordingly for your application.
Source code for the following projects may be downloaded for free on the
BS2P Plus Pack page (see the link at the bottom of email):
1) LCD demo with multi-line mode with custom characters
2) Utilize character definition replacement to create a custom font for
numbers
3) LCD character animation
4) Display 5x10 character set on an LCD
5) Read remote input and update two remote outputs with the I2C PCF8574
6) Phillips PCF8591 4 channel A2D and 1 channel D2A
7) Use an LCD to demonstrate I2CIN and I2COUT
8) Read ROM data from 1-wire device
9) Read and display information from one or two Dallas DS1822's
10) DS2405 addressable switch
11) Demonstrate DS2980 digital pot by adjusting an RC circuit
The Plus Pack includes the following parts for only $69:
l Parallel LCD module; 2 lines x 16 characters (HD44780-compatible)
l PCF8574 Remote 8-Bit I/O Expander
l PCF8583 Clock/Calendar w/ 240 x 8-Bit RAM and 32.768 kHz crystal
l PCF8591 8-Bit A/D and D/A Converter
l 24LC32 32K Serial EEPROM
l (2) DS1822 Econo-MicoLAN Digital Thermometer
l DS2405 Addressable Switch
l DS2890 1-Wire Digital Potentiometer
l (4) Jumper wires packs
l 220 ohm resistor, (2) 1K resistor, 10K resistor
l 100K potentiometer
l 0.01 uF capacitor
l (2) low-current LED
l Normally-open pushbutton switch
Place your order and download source code online at: www.parallaxinc.com
http://www.parallaxinc.com/html_files/products/BS_Accessories/plus_pack.asp
Happy Stamping!
Erik Wood, Parallax
~~Main web site.... www.parallaxinc.com
~~Educational site.... www.stampsinclass.com
~~Spanish site at..... www.stampsenclase.com
599 Menlo Dr. Suite #100
Rocklin, CA 95765
(888) 512-1024 ph. (916) 624-8003 fax
numbers
l 0.01 uF capacitor
Happy Stamping!
Erik Wood, Parallax
Rocklin, CA 95765
