SRAM
While salvaging for parts for my robot project, I came across a 64K
nonvolatile SRAM chip. Is anyone using SRAM in one of their projects? If
usable, what are the basic issues for working with one of these chips? The
chip is a Dallas Semiconductor DS1225AD-200.
Rafe
Rafe
control 15 bits of addressing pins, the 8 data pins, as well as the
Output-Enable and Input-Enable pins. If you want to save power,
you'll also want to use the Chip-Enable pin. This is a total of 25
pins (26 with /ce) so obviously you wouldn't be able to do it with
just a stamp. For SRAM I use an Atmel AVR chip (AT90S8515) along
with a 74HC573 latch. This is a 40-pin chip though, so there's
plenty of extra pins. For a stamp you may want to use 2 shift
registers for addressing and /CE, as well as 2 pins for /WR and /RD
and 8 for I/O. This should be a total of 16 pins, which
unfortunately is the entire stamp.
projects? If
chips? The
> Rafe
$99
Sent: Wednesday, October 03, 2001 6:58 PM
Subject: [noparse][[/noparse]basicstamps] Re: SRAM
> My main project right now involves an SRAM controller. You need to
> projects? If
> chips? The
> > Rafe
an 8-bit shift register be used for data I/O, as well
as a 16-bit SR for addressing, with the Stamp in the
serial side of both? A read op might be 1) shiftout
address to SR1; 2) tell SRAM to read using /RD pin; 3)
shiftin data from SR2. A write would have the same
first step, then 2) shiftout data to write to SR2; 3)
tell SRAM to write using /WR. Pins would be CE, RD,
WR, SR1_dat, SR2_dat, and SClk, 6 total.
Bob Pence
--- capdiamont <capdiamont@m...> wrote:
> there is a 40 pin version of a stamp, with 32 i/o
> lines, costly though, at
> $99
> From: <pyromaneyakk@h...>
> to save power,
> is a total of 25
> able to do it with
> (AT90S8515) along
> though, so there's
> use 2 shift
> which
> I came across a 64K
> one of their
> > projects? If
> with one of these
> > chips? The
> > > Rafe
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
NEW from Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
Barry Michels posted a super project for interfacing to parallel
memory (CF+sram), using 82C55 PIO chips to cut down on the number of
lines required. If you look at the bottom part of his posted
schematic, it is an interface to a '6264 8 kbyte ram.
http://www.barrymichels.com/ide
-- Tracy
>Rafe
