Gender/sexRE: [basicstamps] BS1 Starter Kit, what is that connector?
John, I suppose you refer to gender, do you?
Sorry I cannot help for pins sourcing, as I am not in the USA. Several
years ago (while in Caracas), I was building PCBs and used Molex pin strips
that were easily available. They came in small bars (like a miniature
comb) and I cut them to the required number. I could also buy just the
pins, without the plastic strip, but they were more difficult to mount
straight on the PCB.
Jose Luis
At 13:00 02/10/2001 -0500, you wrote:
>Rodent,
>Close, but I need the other sex so to speak. See Jose's post nearby.
>Thanks,
>John
>Sounds like you need the little female connector that slips over the pins
>sticking out of the board, correct?
>Typically you can get individual connectors on a metal strip or you can get
>a segmented connector you can cut apart with the number of connections you
>want. I'll have to find my Mouser catalog and see what they have.
>I personally use the Molex KK connectors, and I believe the female
>connectors they use will fit the pins on the Stamp boards also. You would
>need to slip a piece of heat-shrink tubing over them to keep them from
>touching one another though.
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Jose Luis
>Rodent,
>Thanks,
>John
Thanks for hanging in there for me. But I got a Digi-Key catalog this week,
and I finally rounded up what I needed. I tried on their website, but as
the saying goes, a picture is worth a thousand words. If anyone is
interested, here is what I have settled on:
DigiKey part number:
929834-02-36-ND "Straight, Single Row Male board mount interconnect"
and
929835-01-36-ND "Right Angle, Single Row Male board mount interconnect"
My order hasn't arrived yet, but I'm pretty certain this is what I was
looking for.
Thanks again,
John
Jose Luis
