Any way to send variables to a function/procedure
While the gosub command is great for reusing code, it would be
WONDERFUL to be able to send variables to them. Does anyone know if
this can be done? Are variables always global? For example I'd like
to do this:
MAIN:
variable1 ='code here to get a value from a pin
variable2 = doNumberCrunching(variable1)
goto Main
doNumberCrunching(aNumber)
aNumber = aNumber + 1
doNumberCrunching = aNumber
If you've programmed in C or vbscript, or regular basic, you know
what I mean.
I'm pretty sure subs can't take variables, but is there any kind of
work around?
Thanks!
to do this:
MAIN:
goto Main
what I mean.
work around?
Thanks!
reach for the stamp.
> it would be
> Does anyone know if
> example I'd like
> to do this:
> MAIN:
> goto Main
> basic, you know
> what I mean.
> there any kind of
> work around?
> Thanks!
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Listen to your Yahoo! Mail messages from any phone.
http://phone.yahoo.com
more work than good sometimes. If you are using a SX
serries stamp you can use scratchpad to create a stack. In C or ASM when you
"pass variables" you are usually pushing the pointers
or variables onto a stack then the function pops them off. We had an application
that required iteration, hence stack based calling.
We wrote a simple set of routines that would pop data from the "stack" (scratch
pad). Just a thought. This is a LONG work around and
may be more trouble than it is worth to you.
MH
Sent: Monday, October 01, 2001 12:46 PM
Subject: [noparse][[/noparse]basicstamps] Any way to send variables to a function/procedure
> to do this:
> MAIN:
> goto Main
> what I mean.
> work around?
> Thanks!
things like complex branching (if x then instruction, for example, rather
than trying to construct a bunch of labels) and functions-with-arguments
into the preprocessor, without changing the stamp as it is in the
slightest. It would certainly make my Object-oriented sensibilities a
little happier, rather than constantly writing spaghetti.
On Mon, 1 Oct 2001, Michael Hendricks wrote:
> There is a way to "trick" the stamp into this sort of procedure. However it is
application that required iteration, hence stack based calling.
(scratch pad). Just a thought. This is a LONG work around and
> MH
> From: <nospam@e...>
> > to do this:
> > MAIN:
> > goto Main
> > what I mean.
> > work around?
> > Thanks!
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
if
like
> to do this:
> MAIN:
> goto Main
> what I mean.
> work around?
> Thanks!
To me, this is one of the big shortcomings of the Stamp BASIC
language, but the reason for it is pretty obvious - there simply
isn't enough memory to do it. You would need some space to store the
parameters (this is generally done using a "stack" that stores the
address of each parameter passed). With only a few bytes to work
with, any kind of a stack would quickly exhaust the available memory.
As I understand it, the Stamp uses only 4 bytes of memory for
subroutine calls - these are used to stack a pointer to the return
address from each call, which is actually stored in EEPROM. This
saves memory, but is the reason subroutines may only be nested 4 deep.
So yes, all variables are global. On the more advanced stamps, you
could use the scratchpad RAM to implement a stack of your own, but
you'd have to do all the management of it in your own code
(placing/removing parameters, keeping the pointer,etc.) and you could
still only call 4 levels deep. So instead of:
CALL SUBR(A, B, C)
you'd have to write: (pseudo-code)
Move A to stack (somewhere in Scratchpad, pointed to by stack pointer)
increment stack pointer
move B to stack
move C to stack
GOSUB SUBR
subtract 3 from stack pointer
Your subroutine would then have to retrieve the data from the stack,
using the stack pointer and negative offsets to find each piece of
data. This is all a lot of work, but it could be done.
If A, B, and C were different sizes (not single bytes), you'd have to
change the moving, incrementing, and decrementing of the stack
pointer accordingly.
Most of the implementation of the Stamp is based on minimizing memory
usage, and this affects the functionality available. This is just one
of many examples. To implement a real subroutine function, you'd
probably need 100 bytes or more of stack space.
Chuck
-D
Sent: Tuesday, October 02, 2001 6:48 AM
Subject: [noparse][[/noparse]basicstamps] Re: Any way to send variables to a function/procedure
> if
> like
> > to do this:
> > MAIN:
> > goto Main
> > what I mean.
> > work around?
> > Thanks!
> CALL SUBR(A, B, C)
> move B to stack
> move C to stack
> GOSUB SUBR
> Chuck
