Interrupts
Hi all,
I am putting together a robot using a bs2 module. The robot will have
various sensors and servos. One of the sensor systems I would like to
implement consists of two wheel-encoders. The setup will probably consists
of a photoreflector pointing to a striped disk attached to each wheel. As a
wheel spins, I want to count the stripes and determine how far the wheel has
gone. I need to be able to count the stripes on both wheels at the same
time and monitor various other sensors. How do I code this without
interrupts? Are there some basic tricks for this kind of coding?
Rafe
Rafe
check out the Stamp project of the month -- it uses a PAK-VI to read a
mouse -- which oddly enough has two optical encoders (if you can figure out
the mechanics to couple it to your robot motion).
Without interrupts you'd have to be sure to poll the sensors at least twice
as fast as the wheel is moving (the Nyquist limit). Barring that you could
wire up a counter but then you need a way to read it (maybe a shift
register) whereas a PAK-VII would read 8 channels at once with one IC. The
PAK-VI and a mouse would only read two but that's all you need and the mouse
encoders are already there.
Al Williams
AWC
*Easy RS-232 prototyping: http://www.al-williams.com/awce/rs1.htm
> From: Rafe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HkYfX43w1aXtlYodhOLLYRT4wrMerP_rjO72dNywb8l38CLSNp8t5KtDFknhR_RPQ5tBK0WVT2hZBloDFwKv]rafe00@e...[/url
> Sent: Monday, October 01, 2001 3:58 AM
> To: Basicstamps@Yahoogroups. Com
> Subject: [noparse][[/noparse]basicstamps] Interrupts
> Hi all,
> probably consists
> wheel. As a
> the wheel has
> Rafe
> from the same email address that you subscribed. Text in the
One method you can use would implement stand-alone separate modules for the
sensors. Tie the powersupplies together. Use latching outputs on the
sensors. When you poll - send a reset to the sensor (this assumes necessary
processor speed of course).
To: "Basicstamps@Yahoogroups. Com" <basicstamps@yahoogroups.com>
Sent: Monday, October 01, 2001 3:57 AM
> Hi all,
consists
a
has
> Rafe
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
