Servo troubles
I am using a simple Hitec servo with a BS2. I have the serial line of
the servo on p7, and supplying 6v from a separate power supply. I am
connecting the ground line from the servo supply to Vss of the Stamp
circuit as recommended in the manual.
Using the following:
again:
pulsout 0,200 ' or for that matter any value from 100 to 200
pause 15
goto again
all that happens is that the servo goes fully to -45 position, even
though it should go to +45 and keeps humming rapidly. The current on
the external supply jumps to .58A!!
When I bring p7 low, the servo relaxes and stay in position, and of
course the current drops to 0.
Please help! is the problem the code? is it the wiring?
thanks
Al Najjar
again:
pause 15
goto again
thanks
Al Najjar
stop. Not good for the servo. This means your numbers for the PULSOUT
statement are not correct.
According to the Stamp manual, a BS2 outputs a 2 microsecond (.000002
second) pulse for every unit in the pulsout command. Most servos need a 1.5
millisecond (.0015 second) pulse to move to the center position.
With this in mind dividing .0015 by .000002 gives you 750. This means a
value of 750 should move the servo to the center position. This value may
vary as the timing on the Stamp and the servo will vary.
What I do is power off the servo and turn it by hand all the way in both
directions, making note of the position. I then figure out where the center
position should be and juggle the PULSOUT value to center the servo.
> again:
> pause 15
> goto again
Futaba servos need from a pulsout signal from 180 to 1170 for full motion.
Try this code to test your servo. Hope it works for you!
'Servo signal on pin 7
'Fully CW = 180
'Fully CCW = 1170
'Variables & Constants
Counter Var Byte
Position Var Word
ToServo Con 7
'*********************Main Program
Start:
For Position = 180 To 1170 Step 20
Pulsout ToServo, Position
Pause 15
Next
For Position = 1170 To 180 Step 20
Pause 15
Next
Goto Start
From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bZxp9TJeFfX1CTIhnTVzMtCpWwQGNZfvyOWxd6LilfjchYdRFgPho7CFF1rw5raQj4IogcaIyoUOZg]brownstamp@y...[/url
Sent: Sunday, September 30, 2001 11:49 PM
Subject: [noparse][[/noparse]basicstamps] Servo troubles
again:
pause 15
goto again
thanks
Al Najjar
motor/geartrain against a mechanical stop. I don't know what numbers to tell
you to use but stay away from the pulse width that stalls out the motor in
either direction.
richard
Sent: Monday, October 01, 2001 7:08 AM
Subject: RE: [noparse][[/noparse]basicstamps] Servo troubles
> The pulse width given in some books is not wide enough. I have found that
my
> 'Fully CW = 180
> 'Fully CCW = 1170
> Counter Var Byte
> Position Var Word
> ToServo Con 7
> Start:
> Pause 15
> Next
> Pause 15
> Next
> Goto Start
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EF8PS7kbDUvVOR_EiVPJp1yOyFR5x9SGCbncoNR5oLTFDbva6n56gZgqaD8sHTBSOxe1wavg13NEedtDjsu-]brownstamp@y...[/url
> again:
> pause 15
> goto again
> thanks
> Al Najjar
