Controlling a store or sun shade
Hi!
Has anybody ever tried controlling automatically a store (or sun shade)
using a BS1?
I am considering having 6 inputs:
- sun is on or off (thru a Light dependent resistor)
- an adjustable reference resistor for the LDR
- Wind speed is under or over a limit (typically using rotary wind sensor
that open/closes a contact on each sensor turn) or any other wind sensor
you may know of. If over, the stor should go "up" rather quickly....
- an adjustable resistor to set the maximum wind speed
- Manual up
- Manual down
The stor motors usually require 2 different relay contacts to close:
- Motor up
- Motor down
- No movement (both relays open)
Could anybody provide some help on the code or the logic flow diagram?
Thanks in advance,
using a BS1?
- Manual up
- Manual down
- Motor up
- Motor down
Thanks in advance,
I have a few questions. First, does 'store' have a speical meaning?
(showing my ignorance and/or confusion)
you mentioned the shade going up 'rather quickly' but your control
is only one rely for up and another for down. This would indicate
one speed for up and another (or the same) for down.
if you wanted 2 (or more speeds) in either direction, you may
need additional contacts. I would not recomend electro-mechanical relays
for any pulse operation.
As far as a wind speed sensor, check Tracy Allen's site for an
anemometer. He has a good description and workable design.
I'm not sure the best light detector or what levels of light you want
to sense, but I ran across a solar collector that uses a simple LED
to detect light. it was basically a pair of LEDs that ran into a
comparator, which ever had a higher output, the comparator switched
the motor to swing the collector so the outputs matched, thus the
direction pointed to the sun. This may not the the most applicable
circuit, but I was intrigued with the idea.
Dave
--- In basicstamps@y..., Jose Luis Juarez <jl.ingenieria@i...> wrote:
> Hi!
> using a BS1?
> - Manual up
> - Manual down
> - Motor up
> - Motor down
> Thanks in advance,
