h-bridge
Archiver
Stamper's,
Where would one obtain an H-bridge (24V, 4A) cheap? What do you people
use?
David Fixemer
fixemerd@a...
402-472-8239
use?
David Fixemer
fixemerd@a...
402-472-8239
motors under or around 2 amps of current
drives a stepper motor, up to 3.5 amps, and 35 volts dc from Allegro.
they have other h-bridge chips as will.
a quick google search turned up these links.
http://www.beam-online.com/Robots/Tutorials/Freeform/H-
bridge/hbridge.html
and
http://www.cadvision.com/blanchas/hexfet/
with a link to his schematic
http://www.cadvision.com/blanchas/hexfet/np-s.pdf
Dave
--- In basicstamps@y..., markallen <mhallen@p...> wrote:
> Can anybody recommend an easy and cheap h-bridge design, say for dc
The L298's work great and are easy to hook up. They cost about $3.49 or so
each.
If your really cheap you can use TIP 31 (NPN) and TIP32 (PNP) transistors
(four of one and six of the other) with six resistors on the bases and eight
diodes for transients. You can also substitute MCS3055 and 2955 transistors
as well. The transistors typically go for about $0.59 cents each. There are
several h-bridge schematics on the internet available. Some guys used TIP
105's and TIP120's and a couple of 2n222's do drive them as well.
If your fancy you can substitute power MosFET's, some of these MosFETS have
almost no on resistance to speak of; you can run 30-60 amps through them and
they barely get warm.
From: markallen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y0wUTjJp3w4s9bDONsa10t9x9iqW7QWspXD9pFStWZSJmNJmbBCB0YNPZPZyzI_Ic4EoNSbJP3nXqNU_1vhJO9BF]mhallen@p...[/url
Sent: Thursday, May 02, 2002 5:37 PM
Subject: [noparse][[/noparse]basicstamps] H-bridge
<www.bobblick.com> Nice, simple, reliable.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
> From: markallen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JbnNhY-u3p385e3w42efu4uwiICZhx2IArPDrpvczQA0PzuEuW6hFAWwykV9skh37pW1KuwilEfu1WCdmf394c10Ew]mhallen@p...[/url
Our L298 Kit is just that. It is a complete kit: PCB, all parts and instructions
for $17.95 US. Connects directly to a Stamp
http://www.HVWTech.com/motorcontroller.htm
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW FPGA Experimenter Board
http://www.hvwtech.com/intro-fpga.htm
I am new to stamps and i had a question.If i could get any help whith code
example for LMD 18200 H-bridge. My stamp is a BS2.
Regards.
K-I Nilsson.
I just got a handfull of beeper dc motors(small) and I want to create
a simple controller for them(foward and reverse and stop) I tried the
article by scott edwards on the parallax site for a half bridge. I
can't get it to work. Can anyone give me a suggestion?
Curtis
control them is with a Pololu mini controller.
http://www.parallax.com/detail.asp?product_id=30052
If you want to grunt it out yourself, the new NX-1000-24/40 board has an
opamp driver onboard that's easy to use -- check out the docs for the
circuit and code:
http://www.parallax.com/dl/docs/prod/boards/28137.pdf
-- Jon Williams
-- Dallas Office
From: cenlasoft [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=i5S-f10T8QCw7QHJvPquWOU39ZPTyNinryrFHsHR2w9NHTHSiXxBTKtnvuIhjfoRnsV34nnd1ded]cenlasoft@y...[/url
Sent: Tuesday, February 10, 2004 2:42 PM
Subject: [noparse][[/noparse]basicstamps] h-bridge
Hello,
Curtis
stamp module.
http://www.geocities.com/jimforkin2003/
jim
From: cenlasoft [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M1AMXYsoaYIF78ODFULUr62Z5HLmI1y94gSm6xlmgGcYcuYNKUDOOAUre7VimirJ_Q858R4Ubn6--ioVHg]cenlasoft@y...[/url
Sent: Tuesday, February 10, 2004 3:42 PM
Hello,
Curtis
Yahoo! Groups Links
