capturing multiple serial values
Hi all,
I'm trying to capture a serial string of values by the BS2.
The serial string are a series of numbers, such as:
101,1,3,4,5,10
The string can be formatted to have any characters bewteen them.
I need each of these stored into word or byte variables.
Using SERIN 16,84,[noparse][[/noparse]DEC num] I can catch the first, is there a way to
capture all at the same time?
Martin Hebel
Need a GUI interface for monitoring and control?
www.selmaware.com/s-plot
www.selmaware.com/tutorials
101,1,3,4,5,10
Martin Hebel
I use the following line of code in one of my app's to
capture seven variables. The "Wait" will have the code
sit and continuously poll the line until the ASCII "U" arrives,
and then once triggered, the data will be captured.
Serin 16, 84, [noparse][[/noparse]("U"), dec1 Transport, dec4 Size, dec4 Mask, dec5 LCD, dec5
Lens, Dec4 Pre, Dec4 Post]
As you can see, the Transport is a one place variable, the Size, Mask, Pre, and
Post variables are 4 places,
and the LCD and Lens variables are 5 places.
You can set these up for different bit lengths as I did, however, be careful to
"always" send your data
in the prescribed size, or you will get errors. For example, if you want to send
the number 100 to a variable capture set up for four places, you must send it
as 0100, or the code will accept
the first three numbers "100"and the first number of the next variable as its
"fourth" number to satisfy the variable
declaration of dec4. I hope I've made this clear.
Russ
Sent: Thursday, September 27, 2001 11:51 PM
Subject: [noparse][[/noparse]basicstamps] capturing multiple serial values
| Hi all,
| 101,1,3,4,5,10
| Thanks,
| Martin Hebel
| To UNSUBSCRIBE, just send mail to:
| basicstamps-unsubscribe@yahoogroups.com
| from the same email address that you subscribed. Text in the Subject and Body
| Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
-MH
--- In basicstamps@y..., "Russ Bassani" <RussBassani@a...> wrote:
> Hi Martin,
LCD, dec5 Lens, Dec4 Pre, Dec4 Post]
Mask, Pre, and Post variables are 4 places,
be careful to "always" send your data
want to send
must send it as 0100, or the code will accept
variable as its "fourth" number to satisfy the variable
> Russ
> From: <martin@s...>
> To: <basicstamps@y...>
> | Hi all,
> | 101,1,3,4,5,10
way to
> | Thanks,
> | Martin Hebel
> | basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
What did your line look like?
Russ
Sent: Friday, September 28, 2001 9:14 AM
Subject: [noparse][[/noparse]basicstamps] Re: capturing multiple serial values
| Thanks, tried your line, and similar, with no success.
| -MH
| > Hi Martin,
| want to send
| > Russ
| > From: <martin@s...>
| > | Hi all,
| > | 101,1,3,4,5,10
| way to
| > | Thanks,
| > | Martin Hebel
the background put characters into the buffer. Then you test for data in
the buffer and if there is any you grab the bytes FIFO one at a time and
assign them to a byte variable. Simple, but you need a BEEXTWENTYFOUR to do
it.
From: martin@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_UZkOGzDS_pPAWWw_bT9JsDNmjfjZK8X6EeAFg0RFPLffxuH97R7txQfpQ6vmoV1-v1VXbO44Hiy5A]martin@s...[/url
Hi all,
101,1,3,4,5,10
Martin Hebel
become problematic at 4800 baud and above. I have info on the
execution times for the serial commands posted at
<http://www.emesys.com/BS2rs232.htm>.
Solutions:
-- try a lower baud rate (if possible) and use WAIT modifiers
-- use a BS2sx or BS2p to get faster response
-- input the entire string using the STR modifier, and then parse
it into decimal values later. This eats up the main RAM, but is the
fastest way to capture data on a BS2.
-- use a BS2p with the SPSTR modifier, to put up to 127 characters
into the scratchpad RAM, very fast, and then parse the string into
-- burn an SX18 chip with the code that Al included with his
Stamps-in-class SX tutorial, an RS232 buffer. Then you could read
the data at a leisurely pace from the buffer.
best regards,
-- Tracy
>Hi all,
>101,1,3,4,5,10
>Thanks,
>Martin Hebel
9600 baud.
Currenly I am requesting 6 different values from StampPlot Pro for
interactive PID control, which the back-and forth time takes about 1 second.
I was hoping to request all the data at once and parse it in to minimize the
request/accept.
But, unless I go in and modify SPP to have a delay between each character
sent, looks like I am stuck for a general, universal example. I may test out
using another pin at 2400 baud just to see if I can do it.
I'll post the example when done this weekend and drop note.
-Martin Hebel
Even the programming port can be used at lower baudrates!!
regards peter
Oorspronkelijk bericht
Van: Martin Hebel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CCRmovvs1229nrTHnJvLja7mCb2XiGMHJqgZrysKRHJwYw9kC0zzH_B9O5CxsqDwrzHJy0ohzCW1Og]martin@s...[/url
Verzonden: vrijdag 28 september 2001 20:32
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Re: capturing multiple serial values
Thanks Tracy, I am using pin 16, the programming port, so stuck there at
9600 baud.
request/accept.
-Martin Hebel
>9600 baud.
>request/accept.
>-Martin Hebel
The "programming port", logical p16, is not limited to 9600 baud. It
can do all the same baud rates as the other pins.
One other option I didn't mention is hardware flow control, but SPP
would have to support that. Also, it would help out a lot if SPP
could be set to send 2 stop bits.
-- Tracy
(of course!) as I have often, so I may try slowing it down, and SPP
supports all common baud/bit/stop bit configurations. But once I slow
down the baud rate, may negate what I am trying to transmission.
Thanks again,
Martin
there at
> >9600 baud.
1 second.
minimize the
> >request/accept.
character
may test out
> >-Martin Hebel
It
> -- Tracy
