Baud....
OK, I know this is a simple question, but I'm a beginner so I feel
justified. Hz is one cycle per second, but what is baud? I want to
send and recieve serial data via the BS1, but none of the books I
have mention how fast baud is. Any help would be appreciated.
serial port the bits are clumped into bytes with pauses bewteen, so
technically you can't say bits per second because it varies.
Baud is essentially how fast the bits in the byte are transfered, so
9600 baud is about 9600 bits per second for that chunk of data, then
a pause, then another chunk. Also, a serial string is more than 8
bits because there is a start, stop and possibly parity bit. but
typically, there are 10 bits to one character sent.
The simpliest way calculate what you need to use for the various baud
settings it to look it up on the SERIN and SEROUT instructions in
your stamp manual.
Even when programming in Assembler, such as on the 8051, most
controllers provide a table to refer to lookup the proper values for
the common baud rates.
-Martin Hebel
SelmaWare Solutions
Serial Data? Plot Data and create GUIs for your Stamp with StampPlot.
http://www.selmaware.com/s-plot
http://www.selmaware.com/tutorials
The actual definition of baud is fairly complex, but in these
discussions it is used interchangably with "bits per second" (bps).
If you are sending data via a serial port at 9600 bps, the time to
send each bit is 1/9600th of a second. Typical serial communications
is in what is generally referred to as asynchronous mode, which means
that a "start" bit and a "stop" bit are attached to each data
character that is sent. If you are sending bytes (8 bit characters),
which is most typical, the addition of a start and stop bit means you
are actually sending 10 bits for each byte - at 9600 bps, you can
theoretically send 960 bytes per second. This assumes that each byte
is immediately followed by the next byte with no delay - real systems
seldom achieve this actual speed. Just don't confuse bits per second
with bytes per second, which is generally about 1/10th the speed.
A guy who designs modems will tell you that baud rate and bit rate
are not the same thing, but for our purposes we can assume they are
identical.
Think of it as meaning "bits per second" and use the "baudmode" settings
provided in your BS1 manual and you won't have any (programming) problems
when it comes to Stamp communications. You can stop reading here and you
won't miss a thing that really matters to Stamp communication.
Technically baud is the reciprocal of the duration of the shortest signal
element in your data encoding scheme. The difference between baud and bits
per second really shows up when using higher speeds that typically have
advanced modulation schemes that send more than one bit of data at a
time. If a modem sends two bits at a time, the speed of the modem
expressed in bits per second is twice the speed expressed in baud. BUT....
these are characteristics of the communication channel, NOT characteristics
of the Stamp-to-modem digital serial interface. You only need to be
concerned with, for example, how fast you must send digital data bits
serially to a modem, not what sort of analog modulation scheme the modem
uses over it's communication channel to another modem.
It's complicated, but it doesn't matter with a Stamp, so if I've explained
it incompletely or confusingly, just ignore it, use the parameters defined
in the BS1 manual under SERIN and SEROUT, and you'll be fine.
Jim H
my application. It's kinda long, but what the hey:
I have the need to detect sunlight in two places at the same time.
One reading in town and one at my home. I figure that I'll take a
reading myself in town, while the BS1 takes data from a photocell and
saves it on it's hard drive (then powers down COMPLETELY, retaining
the data ONLY on the hard drive), then when I get home, I power it up
and read the data. I thought it would be simple, but it's transfering
the data from the BS1 to a serial to parallel shift register that I
can't do. I have other apps that will also be taking up pins on the
BS1, so I MUST do serial data.
So my problem is this: what speed to set the clock to retrieve the
data from the BS1? That is where baud comes in. I've searched all
through that book and I can't find a blame thing. That is my trouble.
listed for the BS1, I'm going to assume it's 9600 for DEBUG.
Typically, data can be sent back to the PC by using the DEBUG
instruction. Just as you can debug to your screen, you are sending
back serial dta. This data may be captured by another program,
instead of the debug window, and stored.
You can also use the SEROUT instruction where you define the baud and
pins.
Our StampPlot programs can accept serial data from the Stamp and plot
them, or log them. An option is to to store the data in the EEPROM
of the stamp, and then dump it at your leisure, depending on how much
data you need to store and how much EERROM memory you have
remaining. StampPlot Pro can easily accept the data and log it,
either as it is measured, or as it comes in. If you would like to go
this route, let me know and I can assist in helping you get setup for
this.
Or, you could most any terminal program to accept then save your data
as a file.
I personally have never programmed much on the BS1, but I think I
have one around here somewhere.....
Martin Hebel
SelmaWare Solutions
> Wow, that is a lot of information. I suppose I should have included
my cp, but I would appreciate it if you'd show me how cause I'm still
new to all of this...
I'm using the POT function to retrieve the resistance of a photocell.
I want to use the BS1 to convert that data to light levels (10 or so
levels). That's about it.
store data, and the value:
Write location, data
With each read, incrememnt the location and store into the next
memory location starting at 0. I'm not very good with BS1 syntax so
take it with a grain of salt.... just trying to demonstrate some
structure here.
light var byte
loc var byte
x var byte
Loop:
pause 1000 '1 second pause
Pot 5,10,light 'read value
Write loc,light 'store in memory
If in0=0 then dump 'if button on p0 is pressed, dump data
loc = loc + 1 'incrememt memory location
Goto Loop 'repeat
Dump:
for x = 0 to loc 'loop to read back values
read x,light 'get value from memory
debug #b2,CR 'display value
next 'next value
goto Loop
One caution, storing can start at location 0, but if you write too
much data you can overrun your program space. Please see you manual
on the Write instruction for more detail.
-Martin Hebel
and
http://www.siu.edu/~imasas/est
> That sounds good, I guess I haven't thought about sending the data
to
still
photocell.
so
Your original question asked for a general definition of "baud" and
maybe you got more than you bargained for.
The BS1 is capable of just 4 baud rates, 300, 600, 1200 and 2400.
This is well explained in the Stamp manual under the SEROUT and SERIN
commands. It is on pages 59 to 65 in th v1.9 manual. Here is a demo
of how to do it at 2400 baud, to transfer 50 bytes from the eeprom of
the BS1 to the eeprom of the BS2:
On the BS1, assuming 50 bytes stored in eeprom:
symbol i=bo
symbol x=w1
for i=0 to 49
read i,x
SEROUT 0,N2400,(x) ' on p0, 2400 baud, resting low
pause 12 ' give the BS2 time
next
end
On the BS2
i var byte
x var word
for i=0 to 49
SERIN 0,396+$4000,1000,error,[noparse][[/noparse]x] ' on p0, 2400, resting low
write i,x
next
end
error:
debug "didn't get 50 bytes, try again",cr
end
If you are transferring from the BS1 directly to a PC, the same BS1
program should work, except use
SEROUT 0,N2400,(#x,32) ' on p0, 2400 baud, resting low
The # makes it send the data as a numerical string instead of a
single byte, and the 32 separates the data fields with spaces.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
