RF under sea water? Sending data through water with acoustics
I'm afraid RF cannot propagate in sea water at any practcal distance. Sound
waves or ultrasonics could be used but you will need special transducers
(Hydrophones) that I believe are quite expensive. For low rate data
transmission it is possible that low priced transducers for fishing sonar
applications could be used.
However, I do not know where to obtain these, Hope this might help a
little. Suggest you try with Edmud Scientific in USA.
Regards.
>X-eGroups-Return:
>sentto-1327227-14862-1001568458-jl.ingenieria=ieee.org@returns.onelist.com
>X-Sender: nbrown@t...
>X-Apparently-To: basicstamps@yahoogroups.com
>X-MS-Has-Attach:
>X-MS-TNEF-Correlator:
>Thread-Topic: [noparse][[/noparse]basicstamps] Sending data through water with acoustics
>thread-index: AcFHDGsFs5NlSpzARriEOhBx4tFVkgAB/EuQ
>To: <basicstamps@yahoogroups.com>
>From: "Nathan Brown" <nbrown@t...>
>Mailing-List: list basicstamps@yahoogroups.com; contact
>basicstamps-owner@yahoogroups.com
>Delivered-To: mailing list basicstamps@yahoogroups.com
>List-Unsubscribe: <mailto:basicstamps-unsubscribe@yahoogroups.com>
>Date: Wed, 26 Sep 2001 22:28:04 -0700
>Reply-To: basicstamps@yahoogroups.com
>Subject: RE: [noparse][[/noparse]basicstamps] Sending data through water with acoustics
>There are a couple manufacturers of underwater communications gear.
>They all use radio waves modulated to a certain frequency. I know
>Uwatec is one, but there are a couple others. That might be one way to
>go.
>Nathan
>From: Bill Sherwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qBOZrMMsv5F0jyCVolHVJkV7Tu0vGvAv09SqV0jp3VjsK9E_74joURbNohRcbeLCZSvlQT3PTuZ3-gphUy9iwR4]bill.sherwood@p...[/url
>Sent: Wednesday, September 26, 2001 9:27 PM
>Subject: [noparse][[/noparse]basicstamps] Sending data through water with acoustics
>Hi,
>Rather than deal with all the problems associated with running a cable
>to
>the surface from an instrument at 100m seawater depth, I'm interested in
>sending some data using acoustics. Baud rate could be around 300 as I
>am
>only sending short strings of data every ten minutes or so.
>Can anyone suggest methods or possible ways I could attempt this, or if
>it
>is feasible? What frequency or transducer is best?
>Cheers,
>Bill
>from the same email address that you subscribed. Text in the Subject
>and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to
>http://docs.yahoo.com/info/terms/
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Regards.
>X-eGroups-Return:
>X-MS-Has-Attach:
>go.
>Nathan
>Hi,
>to
>am
>it
>Cheers,
>Bill
distances (a few feet) fine. Have'nt tried DX, but who
knows? The price is right, a few bucks. Might be worth
a look.
Jack
underwater (Polaroid, Mouser etc). It will be immediatly damaged if
submerged.
Underwater acoustics require specially designed piezoelectric xducers.
Matching rx and tx frequency power/sensivity and propagation path is
very critical for distance comms.
ACJacques
goflo@p... wrote:
> Mouser has sealed 40 khz transducers that work short
> a look.
> Jack
The transducers were not immersed, just the faces were in contact
with liquid. Worked OK, no apparent smoke.
The sensors (Mouser 255-400ER18 (RX) and 255-400ET18 (TX) do not
have the usual mesh screen - The face is polished aluminum..
regards, Jack
A.C.Jacques wrote:
> Electrostatic transducers used for air applications will not work
> submerged.
> ACJacques
> > a look.
release enough power.
Regards
ACJacques
goflo@p... wrote:
> Hi A.C. -
> regards, Jack
> > submerged.
> > ACJacques
> > > a look.
You might want to try: http://www.airmar.com/
They are probably the largest supplier of marine
sounder and speedo transducers worldwide.
I was thinking you could hack a cheap marine depth
sounder for your purpose. Most of what you need would
already be constructed and they are available all
over.
Andy
__________________________________________________
Do You Yahoo!?
Listen to your Yahoo! Mail messages from any phone.
http://phone.yahoo.com
As I recall, there's an entire section in one of the Tesla books
(the big red book with all of his notes in it) about underwater
RF in salt and fresh water. I'd just go look it up right now,
but it's buried under rocks and garbage at the bottom of a
closet.
Something about 4.3 mhz... don't remember what. Any Tesla fans
remember this?
-Chilton
