Sending data through water with acoustics
Rather than deal with all the problems associated with running a cable to
the surface from an instrument at 100m seawater depth, I'm interested in
sending some data using acoustics. Baud rate could be around 300 as I am
only sending short strings of data every ten minutes or so.
Can anyone suggest methods or possible ways I could attempt this, or if it
is feasible? What frequency or transducer is best?
Cheers,
Bill
Cheers,
Bill
They all use radio waves modulated to a certain frequency. I know
Uwatec is one, but there are a couple others. That might be one way to
go.
Nathan
From: Bill Sherwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=n4wEtN2EvP38m4103yTTNkpoylMwTsWSt_tPi2ieXqkyYeVStvTt30g2RWjfhklCa6t05RqC01erp6CHweFwTFo]bill.sherwood@p...[/url
Sent: Wednesday, September 26, 2001 9:27 PM
Subject: [noparse][[/noparse]basicstamps] Sending data through water with acoustics
to
am
it
Cheers,
Bill
Your use of Yahoo! Groups is subject to
Kynar piezofilms have a good acoustic match to water:
http://www.msiusa.com/piezo/index.htm
I hesitate to use loud acoustics for that purpose, due to their
possible effect on fish and marine mammals. Greenpeace has been
actively protesting the Navy project that generates underwater sound
at >140dbm. I really don't know what sound levels you would need in
order to transmit only 100m. Probably not much if it could be
focussed up.
I saw an article once that used "rf" at less than 100 hz for
communication in seawater, with very widely spaced antenna nodes.
Low EM frequencies penetrate seawater better than high frequencies.
The Navy uses an ELF antenna in the U.P. of Michigan (coupled to
magnetic geological formations there) to communicate to submarines at
about 70 hz and low information rates.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>Hi,
>Cheers,
>Bill
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
there's not much info available on underwater communications.
Scores of SCUBA equipment manufacturers make units that read a pressure
transducer on an air tank and transmit through the water to a device on the
diver's wrist or console for calculation and display. I am wanting to expand
on this concept, and I am finding tight lips on the subject....
There must be someone in here who knows this field!....
Well???
Chris
> From: Bill Sherwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ldYJ7NWKwhFhKwoDCh3lf96tY30ml9z6rploBe5hrFPA_NR87aup2lUlMubnNj_xZ2urNRcR28U9D8QhOKzKMDUIVQ]bill.sherwood@p...[/url
> Sent: Thursday, September 27, 2001 12:27 AM
> Hi,
> running a cable to
> interested in
> 300 as I am
> this, or if it
> Cheers,
> Bill
>Hi,
>Cheers,
>Bill
Bill,
An excellent idea! I don't believe there is anything special about crafting
your
own transducer. Maybe a waterproof piezo transducer or mylar cone speaker
would work. I believe acoustic waves move through water at about 9600 fps.
You'll have to do your homework on frequency, that is, you may need to send a
tone burst or serial "clicks" . A stamp based instrument at the bottom could
send a series of different frequencies or clicks from its transducer to a
surface
based transducer. Radio shack sells a flat plate piezoelectric microphone
that might work for that. As amplitude is measured at the surface you should
be able to determine the best zone for both transmission and reception. I'd be
interested in hearing more about this project!
Greg Hensley
Lawrence Livermore National Laboratory
Defense Sciences Engineering Division
7000 East Avenue Mail Stop L-369
Livermore, CA 94550
Phone: (925) 423-4850
Fax: (925) 422-2118
Email: hensley1@l...
> At 09:26 PM 9/26/2001 , you wrote:
> >Hi,
or so.
> >Cheers,
> >Bill
I have seen several designs on the web for underwater
acoustic modems.
Bob
nienhuis@w...
