Encoder Info?
I recently recieved a 32 step optical encoder that is marked QRPG-
A475. It had been purchcased from Gateway electronics, but they only
have pinouts available. Have any of you come across datasheets for
this part? I've been looking, but no luck so far. The pins are
suppose to be "5vdc, ground, out A, and out B". Most circuits of the
encoder/IR source/Detector seem to always use some resistors, so I am
at a loss here without the datasheet.
Thanks for the help!
referenced the QRPG-A475 to the manufacturers Agilent Technologies
part number HRPG-AS32#14C. I have uploaded the datasheet to the files
section with the name "Encoder Datasheet"
