Qbasic serial handshaking
Stampers,
Does anyone know how to get a PC to communicate with the stamp. I assume
the stamp has to make some pin high and/or low to tell the PC to wait.
Which pin?
David Fixemer
fixemerd@a...
402-472-8239
Which pin?
David Fixemer
fixemerd@a...
402-472-8239
The stamp program port only uses TxD and RxD to communicate with a PC
(no flow control). If you use any of the stamp programmable pins for
TX and/or RX you may optionally specify a flow control pin that then usually
connects to RTS or CTS. A level converter TTL/RS232 may be required.
Check the SERIN and SEROUT commands in the stamp manual.
Hope this helps
regards peter
Oorspronkelijk bericht
Van: Production Technology, L.L.C. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jtIBTN4qYIfWgNy4f-JQ7tTp1u8__YD9WnLpDQt-OcWwEDjs8fq-UZieei7T_X6YmWIIx9-L5vko]fixemerd@a...[/url
Verzonden: dinsdag 25 september 2001 22:05
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] QBASIC SERIAL HANDSHAKING
Stampers,
Which pin?
David Fixemer
fixemerd@a...
402-472-8239
