tilt sensor
Hello,
I was wondering if anyone knew of cheap Tilt sensors for my robot. I
need to know how steep of terrain it is on and I figure a tilt sensor is the
best. With this in mind I was wondering if anyone could direct me to a cheap
product that is easily integrated with the Basic Stamp2. digital would be
nice, but analogue will do. Any suggestions would aslo be of great use.
Thanks in advance,
Travis
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
Thanks in advance,
Travis
thermostat. Check with your local HVAC people. A number of these switches
can be set at different static angles - and will trigger at different
levels......
ag
Sent: Monday, September 24, 2001 8:06 PM
Subject: [noparse][[/noparse]basicstamps] tilt sensor
> Hello,
the
cheap
> Thanks in advance,
> Travis
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
potentiometer with a rigid wire attached perpendicularly to its axle. Put a
weight (a fishing lead could do) on the other end of the wire, so that
gravity it will turn the axle proportionally to the tilt of the pots body
(the pot's body should be fixed to the robot platform). You will need some
physical space for this system.
Then you can read the pot value using the "pot" command of the BS.
You can read positive and negative tilts just placing the horizontal
position to coincide with the medium point of the pot
If you want to be full digital, use a magnet at the end of the wire and
place a set of reed-switches to detect the tilt.
But it may use too many inputs of your BS! If so, use the switches to
connect resistors in sequence to just one input and again use "pot", this
time to select among the resulting fixed resistor values. You will have to
carefully adjust the position of the reed switches so that each closes
before the previous one opens. Possibly a complicated task!
Can you tell me how to post answers thru the group? I get my messages
rejected ("only plain text accepted) when I respond from my mail client
(Eudora). How do you do it? Is it mandatory to access the group from the
web page?
Good luck!
Jose Luis
>web page?
>Good luck!
>Jose Luis
>Jose -
Send the messages using this address: basicstamps@yahoogroups.com
Bruce Bates
>At 9/26/2001 Wednesday 05:12 PM, Jose Luis Juarez promulgated:
> >web page?
> >Jose Luis
And check your settings at Tools | Options | Styled Text | Send Plain Text
Only.
Jim H
calibration, you simply spin the stepper and pole the mercury switch at each
step. When it changes state, you look up the tilt via look-up table. Just
a thought........
ag
Do You Yahoo!?
using hall-effect sensors suspended in two plastic boxes. the output went to
a/d conversion through the stamp and then controlled servos.
it worked very well.
mikey hart
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
